No Ground......
Old Nov 5, 2010 | 02:33 PM
  #41
Frankie the Fink's Avatar
Frankie the Fink
Army
Are you telling me that you:
a) Have +12V on both sides of a known good fuse for the heater, and,
b) Have +12V at the FAR end of the wire that goes to the fuse box...meaning the end of the wire that attaches to the heater component ?
If you have both of those conditions then, once again, run a long jumper wire from the negative battery terminal to the heater blower housing (or where ever its supposed to be grounded)....
You're on the home stretch now!
Old Nov 5, 2010 | 03:50 PM
  #42
JohnZ's Avatar
JohnZ
The '58-'62's use a really flaky design for the heater blower ground; it grounds through the wire wrapping around the temp control cable from the temp valve to the ground screw on the back side of the console plate. Many folks just run a separate ground wire from one of the blower flange-to-heater case screws to a known good under-dash ground instead.
Old Nov 5, 2010 | 03:51 PM
  #43
Frankie the Fink
Army
Yup! That's where I was heading John!
Old Nov 5, 2010 | 04:49 PM
  #44
1955 copper's Avatar
1955 copper
2015 C1 of Year
Originally Posted by Tinat
Just got the voltmeter and checked every wire and fuse. All is good. Everything gets fire.
Everything is working now except the heater fan blower. When we take it out and check it ,it's fine, we we try it in the car it won't work.
We're pulling our hair out.......
Connect a ground wire to the heater switch cable and a hot wire to the switch hot side ( if it don't work the switch is bad )
Connect a ground wire to the heater housing and run a hot wire to the heater hot wire ( if it works the switch is bad or again not grounded )
Make sure the heater housing is grounded before you do anything
Old Nov 5, 2010 | 05:07 PM
  #45
Frankie the Fink
Army
Its a brand new heater switch Roy as noted a few posts back...
Old Nov 5, 2010 | 05:23 PM
  #46
1955 copper
2015 C1 of Year
He should connect a HOT wire to the heater wire ( not the switch) while it's in the Corvette and it should work if the motor housing is grounded to the heater (unit) and the (assy) is grounded to the Corvette motor or frame or dash support .
By pass the switch and if it runs the switch is connected wrong or screwed up.
Old Nov 6, 2010 | 08:06 AM
  #47
Tinat's Avatar
Tinat
Had to quit yesterday.....too frustrating. I'm going to start back today and try all the above.
Thanks to all, I'll let you know later today what happens.
Old Nov 6, 2010 | 09:47 PM
  #48
Tinat's Avatar
Tinat
WOW........That did it. Thanks to you all.
I really really don't think we would have got this taken care of if not for you guys on this forum.
Thanks again
Old Nov 7, 2010 | 02:24 AM
  #49
Sxrxrnr's Avatar
Sxrxrnr
Thanks again
Dat was a good one.
Old Dec 31, 2010 | 01:36 PM
  #50
Tinat's Avatar
Tinat
I hate to ask this but when this fixed my problem I just quit for awhile (like a month) and shouldn't of. Now I'm back at scratch.
When you speak of this ground wire......do people leave this......is this the only solution to fix this problem??
Thanks and to all a very "Happy New Year"
Old Dec 31, 2010 | 02:17 PM
  #51
Frankie the Fink
Army
You could always try to make the original (badly) designed ground work but why bother...its best just to leave the 'back up' ground in place and ensure proper blower motor operation. Many C1 owners have a similar problem with the fuel gauge ground and have to run an extra ground to the chassis from the sending unit to stabilize the gauge. (I did). That's just life with these old cars.
