327-3970010 casting?
ANY (NOT just an 010) 4in bore block could be used to build a 302-327-350 (and in modified configuration, a 383). The ONLY difference in the above displacements was determined by the stroke: 3in, 3.25in, 3.48in and 3.75in strokes.
ALLLLLLLLLLLLLLLLLLLLLLLLLL 010 blocks were the large journal version (2.45in main journals-2.1in rod journals).
Large journal 327 were manufactured in BOTH 68 and 69. In 68, Vettes got the large journal 327, but in 69 they went to the 350.
AS FAR AS I KNOW, the FIRST 010 block was in 69. The FIRST 4bolt block was also in 69. Even though the first large journal 4in bore block was in 67 (SS350 Camaro ONLY), NEITHER the 67 nor the 68 blocks got 4bolt mains.
I personally have never observed nor had my hands on a 69 327 in an 010 block, but it is certainly possible that they were made. Also, I am NOT aware of any hi-perf version of the 69 327. They were all lo-perf engines, and if I remember correctly, they were primarily in full size sedans.
Thus, again to the best of my knowledge, the 69 010 blocks were ONLY used for 302 and 350 engines.
And as I'm sure all of you know, the 302 came one way and one way only. Period. It was the Z28, special Hi-perf engine with the solid lifter 30-30 cam, 11:1 compression, 2.02 heads and the tallest ever (factory) alum hi-rise intake manifold. The ONLY transmission was a 4sp.
Tom Parsons
For those of you who have ever noticed bare BB blocks with PASS-TRUCK-HIPERF cast into the block, this is why. The same block gets used for either application.
Again, for those of you who want to convert your 2bolt BB block into a "factory" 4bolt block, the cheapest method is to search out the junk 366 BB truck engines. They ALLLLLLLLLLLLL had 4bolt caps. Remove the caps, take your 2bolt 396-427-454 and the 366 truck caps to your friendly machinist and have them installed/line bored/honed. Voila, a 4bolt BB that only a VERY FEW people will ever know started life as a 2bolt block.
Tom Parsons
The 0010 block was never made by GM as a 327, however, it would be an easy build only requires the later 327 large journal crank and the 327 rods. NOTE: the 0010 was used for the 69 302 by destrocking it.
327carguy
Sold it in 71 when I built a "home made" LT1 and used Chevy's first design offroad cam. DANG!
After that engine (about 73), I got into building SB400s and haven't looked back.
Tom Parsons
Tom Parsons
I don't know whether or not the 68 A-bodies (which of course was the Chevelle) got an 010 block. I've not personally seen a 68 Chevelle with an 010 block, but that's not to say they didn't exist. There certainly were a lot of 68 Chevelles with the 327 and there were several 68 Chevelles with the L79 option which was the hi-perf hyd cam 327.
Tom Parsons
Mike T.
Now, that is funny!! But I always enjoy Tom's posts!!
