Alternator Discharge Under 900 RPM
My alternator ('65 365HP) does not charge the battery under 900 RPM or when the headlights are on unless the RPM'S are above 900 RPM. Battery, Alt, Regulator, belt have all been replaced. What would cause a discharge at low RPM only. I replace the regulator twice. Thanks Larry
Alternator pulley too large or crank pulley too small, or you are using a 1 wire alternator. Possible VR if it is an external regulator.
Doug
Doug
Flashback to about 1987 or so, and my 65 roadster did exactly the same thing. Disassembled the alternator and found one of the three stator coil terminals had broken off. Soldered it back together and all was well. You may want to check all your alternator internals if the regulator has been replaced.
Things happen to these car parts after 20 years or 40 that the designers really couldn't anticipate. The stuff just didn't have that design life.
that's probably how they designed the 365hp solid lifter engine, to keep everything intact at higher revs than hydraulic lifter engines could attain. It's not good when the belts come off the pulleys.
If your stock alternator is working as designed, there are several 100amp or more alternators available that will support the headlamps at low rpm. Changing pulleys is also an alternative.
If I take the alternator to the Parts store they should be able to find a bad stator or any internal on their test machine right? I had the alternator (original) rebuilt, but you know how that goes.
Google alternator testing and diagnosis, or something similar.
Doug
Doug
good post and oh sooo true!....
Doug, I have the stock alternator. It has a two prong plug, a batt post and a ground post. That would be what you call the three wire right? It also has an external voltage regulator.
I replaced the factory 61amp alt with a 135amp from Alterstart which has no problem charging the car with a heavy load at idle. In general, the higher the high rpm rating, the more an alt will put out at idle.
I can remember a while back I started the car and went to roll over the headlights. They were slower than I am used to. I haven't had that problem since but I haven't tried the rpm trick.
That was the only time they were slow to roll over. Not before and not since.
Rich
If you have 3" alternator pulley and 6" crank pulley, your engine RPM will be way different to get 2500 alternator RPM than in you have an 8" crank pulley and 2.5" alternator pulley.
if you are going to reply to a post, read it and understand it.
Doug
Necessary to be precise.
Doug
Doug
Thanks for the info.
Rich
