She is in primer!
She is in primer!
Body man sent a few images for Project 396.
Question:
Note 3 holes for fender badge. (Was a 427 badge)
Is the 396 badge 2 holes? Or the same as 427 badge?
Question:
Looks good from the pictures. However, i have to ask why he was so lazy as to not mask off the fuel cap, fuel filler neck grommet, and the rear underside of the car? I get so mad when painters paint wiring, spare tire tub, etc. It only takes a few minutes to mask things off.
The wires I have to redo as we are going from 6 to 4 tail lights.
Looks nice. However, IIRC, you said you were not doing a body off. Looks like frame and other pieces were sprayed with primer making more (not fun or easy) work later.
larry
larry
Location: going faster miles an hour...with the radio on in browns mills new jersey
As the "396" and "427" badges look the same except for the numbers, I'd imagine the "396" badge had 3 holes also.
Received 6,943 Likes
2015 C2 of Year Finalist
Received 1,762 Likes
I'm kidding of course, that was the NCRS in me coming out. I'm okay now , I've suppressed those idiotic thoughts. Mine, like yours, will be far superior to the crap that rolled out of the factory. Nice job.
Jim
The seams and body lines do look to be right on the money. It's going to look perfect.
Did they prefit the headlamp buckets? Mine needed a little tweaking to make them allign right and look perfect (definately not to factory standards). That was done prior to primer.
Joe
Joe
