ZZ4 externally balanced 'balancer'
Old Nov 18, 2010 | 10:38 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Default ZZ4 externally balanced 'balancer' ?????
this is an 'iffy' question....
is the ZZ4 balancer different from the the one i presently use on my 70 LT-1?
if it is different, there is not enough clearance to my front crossmember to use an 8" balancer so i need to find a balanced one that will work on a ZZ4 that is smaller in diameter than the normal 8".
what i have seen on Jegs/Summit/ebay is very expensive... anyone have any suggestions?
Bill
Old Nov 19, 2010 | 11:03 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Bill
Maybe below info will help
GM Performance 88960604 Harmonic Damper
Originally used on 1970-74 350ci LT1, Z28, and L82, this cast iron balancer has an inertia ring that is 1-11/16" wide, has the 1969 and later timing marks and is used on all ZZ4 H0 engines.
I used this 8" on ZZ4 I put in '65 ===> Click Here
Looks like a comparable 6" will work.
George
Old Nov 19, 2010 | 11:14 AM
1COOL60's Avatar
1COOL60
From: Emporia, pay no attention to that man behind the curtain, KS
Bill
Speedway motors has both chrome and painted fluid-filled dampers at reasonable prices. SFI certified, too. They also have rubber dampers.
http://www.speedwaymotors.com/Chrome...pers,1791.html
160
Old Nov 19, 2010 | 11:22 AM
jdk971's Avatar
jdk971
i am not a expert. i have a zz4 on a stand w/ less than 1k miles. the balance or dampner
needs to be neutral balance. the engine is internal balance. it is the flywheel that needs to
be balanced do to the crank end on one pc main seals. i would say you have the right
balancer. i am sure i will be corrected if i am wrong. best of luck jim
Old Nov 19, 2010 | 11:24 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Jim
Plasticman has basically confirmed what you have said; the 383 and 400 engines are the only ones that need an 'externally' balanced dampener.
thanks
Bill
Old Nov 19, 2010 | 11:29 AM
Plasticman's Avatar
Plasticman
Jim
thanks
Bill
Yep, SBC 3.75" stroke engines get an externally balanced balancer (torsional damper). Shorter stroke engines like the 5.7L / 350 CI are internally balanced, and use a neutrally balanced unit.
But as with everything, there are other options. You can internally balance a 3.75" stroke engine (not cheap) and then use a neutral balanced balancer.
Plasticman
To ZZ4 externally balanced 'balancer'
