front brake conversion-'64
Has any one done a "bolt on front disk brake conversion" using your original spindles for a mid year. spec. a 64. looks like the way to go but ????? they make it sound like a 4 hr job, Thanks for any info.
Frank.
You will be doing, master cylinder, brake lines, and spindles etc. If you go with power brakes the hood will not clear in the stock position. We tried several "kits" that would not clear the knockoff wheels. We ended up with stock 65 corvette front disc assembles and a modified power booster mount. John Z is has a recommendation for the master cylinder for drum rears and disc fronts.
To increase the FUN FACTOR, this is the perfect time to add a "line lock."
http://shop.ebay.com/?_from=R40&_trk...All-Categories
I went with new spindles as the HotRodUSA kit without spindles costs as much or more. Doing the front is pretty easy.
You should also put in a dual master cylinder. I put one in and decided not to go with power brakes due to the hood interference on my 63. I can alway convert to power later as a MC is only $50 from NAPA and the brake booster is <$100 but some fiddling with the mounting bracket is required. Putting in the dual master cylinder can be done for $100 if you bend your own brake lines like I did. You would need a 67 front brake block and tie in the rear circuit with the existing brake line. BTW you don't need the 67 style proportioning valve. If you go with keeping the drums in the back, you will have to find a MC designed for disc/drum as the 67 MC is for disc/disc. Someone else can tell you which MC to get as I used a 67 and did 4 wheel disc brakes(PITA on a 63 as I had to replace the complete ebrake with a 64-66 style including all hardware and ebrake bracket/handle I got from a forum member).
My 4 wheel disc conversion was pretty expensive. Then a month ago I bought a complete 65 show car chassis completely restored with new brakes for about the same $$$!!!
Do a search on this conversion. Lots of info and pictures.
(I installed a power brake booster some time ago and works great on my drums, just need better straight stopping )
1963-1964 Corvette / Bottom Kit
Price: $575.00
KIT #: DK787B
braketechsolutions.com
Brake Tech Solutions
10806 Reames Rd. Suite W
Charlotte, NC 28269
Phone: 1-866-509-7332 or 704-509-9210
Email: sales@braketechsolutions.com
General Motors Disc Kits/Power Kits
Ford & Mercury Disc Kits/Power Kits
Chrysler / Dodge / Plymouth / Jeep -Disc Kits/Power Kits
Street Rod Parts, Accessories, & Pedal Assemblies
Custom Disc Brake Kits
Pre-Bent Line Kits
Please leave us your comments!
Date: 02/08/10
Message: All questions please refer to our contact page to EMAIL us otherwise we cannot contact you. Thanks, BTS
General Motors Disc Kits/Power Kits | 1963-1964 Corvette Disc Brake Kit
2009 BTS Catalog
Download
Custom Kit Info Form
Please use this form and send it in with your spindles for your custom disc brake kit.
Thanks BTS
Wilwood makes an aluminum caliper which is a direct replacement for the stock Corvette (comes with braided lines too). Vette Brakes sells a two piece rotor which is a direct replacement for the stock Vette rotor.
http://personal.atl.bellsouth.net/t/t/ttoptony/DrumBrakeConversion.htm
i need zero offset and fitment of knock off wheels.
hotrodsusa/partscityusa already stole my money and never sent me anything and changed all their phone numbers.
im now looking for another vendor.
