Spring Compressor
Old Nov 25, 2010 | 05:56 PM
bmcnitt's Avatar
bmcnitt
Default Spring Compressor
Can anyone recommend a make and model of coil spring compressor you have bought that definitely works on a C2. Hoping to maybe buy one from Summit or someone but it sounds like you can easily get one that will cause problems from reading old threads.
Thanks - Brian
Old Nov 25, 2010 | 06:18 PM
Grey Ghost's Avatar
Grey Ghost
The steel plate and threaded rod is the best method.
Old Nov 25, 2010 | 09:23 PM
John McGraw's Avatar
John McGraw
That's what I use as well! A piece of 5/8" all-tread, a couple of nuts and some scrap steel and you are good to go. Just insert the rod through the shock opening and put a plate across the hole in the bottom of the A arm to pull against. Pretty hard to beat the price on this model.
Regards, John McGraw
Old Nov 25, 2010 | 10:22 PM
kh65VetteT2's Avatar
kh65VetteT2
5th Gear
Default coil spring compressor
Thanks - Brian
I am using a compressor for a Mercedes which is very good for a wishbone suspension. I am a new this forum, and I don't know how to show pictures here, but I have several pictures showing installing coil springs by using this compressor.
Old Nov 25, 2010 | 10:26 PM
kskid's Avatar
kskid
go to top of the forum page and there is a thread about how to post pics.
also a hearty welcome. this is a good place to learn, and a wealth of knowledge here.
Old Nov 25, 2010 | 10:35 PM
midyearvette's Avatar
midyearvette
Old Nov 25, 2010 | 10:48 PM
bmcnitt's Avatar
bmcnitt
How long does the 5/8" rod/bolt need to be and where can you get one cause I would geuss it probably is what 18" long or so?
Old Nov 25, 2010 | 10:59 PM
kh65VetteT2
5th Gear
Old Nov 25, 2010 | 11:01 PM
kh65VetteT2
5th Gear
Old Nov 25, 2010 | 11:02 PM
kh65VetteT2
5th Gear
The above two pictures are showing my spring compressor.
Old Nov 25, 2010 | 11:08 PM
Vogie's Avatar
Vogie
Looks very German.
Old Nov 26, 2010 | 12:38 AM
bmcnitt's Avatar
bmcnitt
Very nice but the divots your are taking out of that golf mat are a little deep!
Old Nov 26, 2010 | 01:01 AM
kh65VetteT2
5th Gear
It just became after practices for many years. Ouch! I have a new one now. Thanks.
Old Nov 26, 2010 | 09:40 AM
John McGraw
I just bought a 2' long piece at Home Depot. It probably does not need to be more than about 15", but I never cut it off. It will work for almost any car that uses standard shocks that go through the center of the spring.
My lower plate is actually a chunk of angle iron with a hole drilled through one leg. It just needs to be long enough to span the shock hole in the bottom of the A arm. Always use a large washer under the top nut, as you don't want the nut to chew up your top shock mounting cup.
Old Nov 26, 2010 | 10:50 AM
silverslashstreak's Avatar
silverslashstreak
Here is a picture of how I do it with the threaded rod.
Simple and inexpensive
Jeff
Old Nov 26, 2010 | 12:35 PM
Geek's 65's Avatar
Geek's 65
Jeff
Don't forget safe. If something went south as you are dropping the lower A-arm - the rod contains the spring from going far.
To Spring Compressor
