Mandrel-bent exhaust systems
Anyone know who makes mandrel-bent 2 1/2" exhaust pipes for the C2?
I don't need stainless steel - aluminized is fine. I just want to replace the stock replacement 2 1/2" pipes which are not mandrel bent - the squashed bends and ovalized cross section of these pipes hurt the performance too much IMO. (I only need the pipes from the trans cross member to the mufflers, but don't want custom pipes which won't be compatible with a stock system.)
Thanks!
Thanks!
Best bet is to go into a muffler shop and tell them what you want. They may be even able to just cut the old bends out and weld in mandral bent pieces saving you a ton of $$$.
Just searched CC's website and found that they're all push bent, not mandrel bent in which a circular cross section is maintained. I called them also and they confirmed that they're all push bent, not mandrel bent.
I do know that Stainless Works sells the mandrel bent pipes, but looking for other vendors. Will call Allen's next.
Received 1,844 Likes
Their name escapes me at the moment. I have one of their systems on a '70 BB Nova and it fit and looked perfect.
I just remembered: http://www.gardnerexhaust.com/
The guys in New Jersey. They make muscle car exhaust systems as original right down to the last wrinkle. They started making Corvette exhaust a year or so ago.
Gardner exhaust doesn't do mandrel bent either, but they sounded very interested and helpful for those wanting a correct system.
The Gardener exhaust is made like original OEM. Not like typical muffler shops.
PS.I do like the way CCentrals are oval in certain sections for increased ground clearance.
I wouldn't worry about a good muffler shop compression bend. If you are using 2.5" pipes, you will not lose much flow vs. mandrel-bent. 99.999% of muffler shops CANNOT do mandrel bends because nobody has the equipment. What are you going to lose with compression bends - 3 HP? I wouldn't worry about it.
