winter storage outside problem
Old Dec 7, 2010 | 11:34 PM
LT1driver's Avatar
LT1driver
Default winter storage outside problem
unfortunately, I have to store a car outside in winter. temps could get down in teens but usually only low 20s thru february. Motor is 350, no radiator in car, car is covered with car cover but that is it.
Problem: car will not run so can not circulate anti-freeze thru motor to protect, radiator not in car, unknown if any water remains in motor(was before became unrunable (is that a word) without radiator in it for short time.
Question: if I pour anti-freeze thru top rad hose connection and do so until it runs out bottom hose connection will it be entire block or????? I don't want to have block crack. Any other suggestions-remember car can not be moved. thanks.
Old Dec 8, 2010 | 01:58 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
I'd probably remove the drain plugs at the sides of the block and drain it along with the rad, then replace them and fill both with an antifreeze mixed 50/50 with distilled water. You could rig something to blow out the block with air before filling to try and get all the water out. Fill through the thermostat port on the manifold, but you might want to block off the hose outlets while you do.
If there was just water in it, make sure you drain the heater core as well.
Old Dec 8, 2010 | 02:19 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
If the lower rad hose is off, there is very little water/coolant left in block, maybe 1 gallon out of 4 originally in the system.
it won't crack, as there is plenty of expansion room if ice forms.
Doug
Old Dec 8, 2010 | 07:24 AM
MikeM's Avatar
MikeM
Doug
If the heads are still on it, that means the block is still full of water.
I'd pull the block plugs and drain it. If you can't get to the block plugs, raise the back of the car with a jack and let drain what will out the water pump. Let the back end of the car down and then refill the cooling system with straight anti freeze with the lower hose blocked off.
You can also go buy a cheap pump from a place like harbor freight and circulate the coolant via the heater hoses.
I don't know where you live but it's been in the teens/close to single digits at night here and not above freezing the last few days. You may be too late.
Old Dec 8, 2010 | 08:21 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I believe they have sold dipstick heaters for years. You plug it in, place it in your motor and it should keep things warm enough...quite popular in cold environments.
http://www.amazon.com/Kats-15200-Dipstick-Style-Heater/dp/B000BO74DG
You don't necessarily have to have oil in the car for it to work well enough..
I have known some folks to throw a cheap electric blanket over their motors in the winter...
http://www.amazon.com/Kats-24150-Watt-Universal-Heater/dp/B000I8TQD6/ref=pd_sim_auto_4
It doesn't take too much to raise the temp if you are out of the wind...these items are
very cheap to operate and you could do both for under $50. Some folks do both in case one or the other item should malfunction.
I've even used a plain old droplight
strung beside a block to keep things warm overnight.
Finally, back when I was poor (I mean REALLY poor) and had to choose between buying gas to get to work and anti-freeze. I used to drain the block on my 283 1960 Impala in the driveway each night and refill it from the water hose each morning. Did that for a month in low 30* high 20* temps with no problem. Never even blew a freeze plug.
Its funny to think back on it now...
Old Dec 8, 2010 | 08:32 AM
66since71's Avatar
66since71
Surprised no one has mentioned removing the thermostat before trying to circulate any coolant... it will certainly be closed. Using the heater hoses for circulating coolant may bypass the thermostat, making removal unnecessary.
You'll never get all of the old coolant out, however if it had antifreeze in the system to start with, you should be OK doing nothing. Antifreeze doesn't go bad, just the corrosion inhibitors in it...
Harry
Old Dec 8, 2010 | 08:55 AM
Steve59's Avatar
Steve59
NOW I know why you moved to Florida!
Old Dec 8, 2010 | 09:09 AM
Texaspilot180's Avatar
Texaspilot180
All you really need to do is avoid a "hard" freeze event, such as sitting at below freezing temps for days and days. A cheap electric blanket with a thermostat to cover the engine, or similar "heater" connected to a timer set to come on when it will be the coldest and go off a few hours later. I've been in a similar spot a few times with projects, and would use anything that safely generated enough heat to keep things from freezing. In the engine compartment, hood down, covered, doesn't take a lot of heat. A small heat lamp, electric blanket, etc. I had a BB car once i was afraid of freezing, and had visited an aircraft engine shop where they had a box of old electric pad style heaters they had stripped off air cooled aircraft ngines and they gave me a cople of old ones so I used a little glue, attached one on each side of the block, wired them up on a timer and presto, instant heat when I needed it and where I needed it. When spring came, pulled them off and that was that. Whatever you decide to try, not too hot so as to start a fire or melt stuff...
Old Dec 8, 2010 | 09:16 AM
Frankie the Fink
Army
Its awful Steve. Considering I come from Pittsburgh.
If temps dip below the 40s in Orlando I freeze just thinking about it and crank up the propane fireplace until the wife complains about heat stroke.
Old Dec 8, 2010 | 09:31 AM
RatDog's Avatar
RatDog
St. Jude Donor '20 thru '25
And that's exactly why we're moving back to Florida . . . it's -7 degrees outside right now!
-- Steve
Old Dec 8, 2010 | 10:07 AM
Mike Ward's Avatar
Mike Ward
Pull all the hoses off, remove the thermostat. Pour a half water half antifreeze mix into the holes until it runs out the bottom.
Old Dec 8, 2010 | 11:07 AM
Kerrmudgeon
Frankie those electric things are great unless the power goes out, which it has a tendency to do with ice storms and the like, remember..., just sayin z'all...
Old Dec 8, 2010 | 02:21 PM
63split63's Avatar
63split63
Doug
If you do not remove the drain plugs and drain the block ( be sure the drain holes are not plugged up with crap ) and there is plain water left in the the bottom of the the block and it gets cold enough it WILL crack down along the oil pan . Just draining the hoses does not get all the fluid out .
Bill Purdy
Old Dec 8, 2010 | 02:50 PM
LT1driver's Avatar
LT1driver
I will have to try and get the drain plugs out and put straight anti-freeze in as I have no way to get electrical power to it, in a storage lot, not at house unfortunately. Note: car is in west texas on the plains.
Old Dec 8, 2010 | 02:54 PM
LT1driver's Avatar
LT1driver
Frankie, never heard of anyone draining water overnight and refill next day, that is worst than changing a head on big block in winter in apartment parking lot while it was sleeting and snowing in Arkansas as I did once. ah, but I was young, stupid and only 20 years old and it was my only car needed for work/school.
Old Dec 8, 2010 | 03:08 PM
AZDoug's Avatar
AZDoug
If the lower hose is off, the water level is about at deck height at the rear outside of the motor, the heads and block water jacket at the inside top of the cylinders are empty.
Pulling the heads with the lower hose off,a nd water pump on car, yields a spill of about 1 pint per side.
If the OP is uncomfortable, add some antifreeze as others have suggested.
I have stored motors in car in MT for the winter with no radiator,a nd fluid in the block with no problems. Though the fluid was probably not straight water.
Yes, come to think of it, the couple times I did this, the fluid was an antifreeze mix left in the block and wouldn't have frozen.
Doug
Old Dec 8, 2010 | 03:29 PM
jfr's 63swc's Avatar
jfr's 63swc
As a point of reference, I just changed the anti-freeze in my 63' 327/300HP last week as a part of replacing my heater hoses. I drained the radiator through the drain valve on the bottom of the radiator into a pan. I then transferred the anti-freeze to jugs for disposal. I got almost 2 gallons this way and another quart from the heater core that did not drain out fully until I actually removed the heater hoses. I even removed the thermostat housing and thermostat. I then removed the waterpump so that I would have a good place to flush the block from - probably not necessary, but I did. Anyhow - that left only the drain plugs. I removed them and let each side drain into a pan. When I transferred this to jugs, there was almost one gallon from EACH side! Bottom line, almost 2 gallons remained in the block!
In the original posters situation, he probably should pull the drain plugs to prevent damage from freezing! Especially if he is not sure if it is water or anti-freeze is remaining.
For those just changing the anti-freeze. If you just flush the block without pulling the drain plugs, you will have almost 2 gallons of un-distilled water left in the system. Probably not a good idea!
Jon
To winter storage outside problem
Old Dec 8, 2010 | 03:33 PM
JohnZ's Avatar
JohnZ
There are a couple of quarts of coolant trapped in the cylinder water jackets on each side, and they're not cross-connected. Remove the drain plug on each side, just above the pan rail, drain (after poking in the hole to make sure it'll drain), and leave it for the winter. With no water in it, it won't freeze.
Old Dec 8, 2010 | 03:38 PM
MikeM's Avatar
MikeM
Doug
That's about right.
Old Dec 8, 2010 | 07:19 PM
LT1driver's Avatar
LT1driver
checked today and there is some anti-freeze in it, must be above +20 or so because that is best I can determine with my tester....I did pour a gallon in through the thermostat hole and will go out tomorrow and drain if possible from block plugs...radiator in car and could hear new anti-freeze gurgle into it. I still have some days before we get into hard freeze nights time. thanks for help......car is completely covered with cover and tarps from harbor freight over that.
