A Arm Flaps
Old Dec 13, 2010 | 10:09 PM
jbutler's Avatar
jbutler
Default A Arm Flaps
It looks like the flap is supposed to fold over the A arm in the AIM, but on most photos I see posted, the lower part of the flap is on the inside of the engine compartment.
What way is correct?
This is how mine are.Name:  A Arm Seal.jpg
Old Dec 13, 2010 | 10:34 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
My 63 is tucked in like yours.That way you can easily access the shock studs.
The others didn't complete the process.
Old Dec 13, 2010 | 11:09 PM
4440stevesvette's Avatar
4440stevesvette
This is how mine are.Attachment 47663210
You are correct!!!
Old Dec 14, 2010 | 12:30 AM
mrg's Avatar
mrg
I wondered about that too. I had mine installed wrong. .. Thanks for posting the pic!
Old Dec 14, 2010 | 08:49 AM
Glasshole's Avatar
Glasshole
Mine are like that on my 63' too. If I don't tuck them in the one on the passenger side will actually get sucked up into the fan belt.
Old Dec 14, 2010 | 09:56 AM
davewh's Avatar
davewh
How are they attached?
Old Dec 14, 2010 | 10:08 AM
JohnZ's Avatar
JohnZ
They were attached to the inner fender with 16-ga. steel staples.
Old Dec 14, 2010 | 01:01 PM
toddalin's Avatar
toddalin
IIRC, the staples are supposed to be stainless steel.
Old Dec 14, 2010 | 01:13 PM
mrg's Avatar
mrg
The original factory staples holding on my dust shields were regular carbon steel. They were reused. SS staples tough to bend.
Old Dec 14, 2010 | 01:17 PM
1snake's Avatar
1snake
Nope.
Old Dec 15, 2010 | 04:17 PM
JohnZ's Avatar
JohnZ
Nope. That's what most of the vendors will sell you, but they're incorrect, difficult to work with, and will get deductions in judging. The original Bostitch pedestal-mounted industrial staplers the plant used were fed by 25-pound spools of 16-ga. plain steel wire that were cut and formed into shape by the stapler just before it punched them through the flap and fiberglass.
Old Dec 16, 2010 | 09:50 AM
salty_waders's Avatar
salty_waders
I wish I had one of those machines Ive had new flaps for years but havent installed them because I know how difficult those staples are. Ive heard of others using wire or even paperclips.
Old Dec 16, 2010 | 10:39 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
I used the stainless staples from LIC when I installed my A-Arm flaps. I clamped the flaps in place and drilled from the body side through the flaps using the existing staple holes in the body. Then I inserted the staples through the flaps and bent them over using channel lock pliers and final crimp at the bend with a vice grip. Came out great.
Old Dec 16, 2010 | 11:09 AM
Tom454's Avatar
Tom454
Old Dec 16, 2010 | 06:28 PM
davewh's Avatar
davewh
how many staples should be placed and where?
Old Dec 16, 2010 | 07:12 PM
rick66's Avatar
rick66
I tried using the vendor supplied staples. I struggled mightily to bend them, got frustrated and switched to the same gauge aluminum wire. Frustration eliminated, but of course "not to code".
Old Dec 16, 2010 | 09:57 PM
LT1driver's Avatar
LT1driver
I was able to reuse my originals on my 67
Old Dec 17, 2010 | 01:06 PM
JohnZ's Avatar
JohnZ
Just get a little blister-pack spool of 16-ga. steel wire from the hardware store and make your own.
Old Dec 17, 2010 | 02:44 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
It's all spelled out in the AIM.....UPC 11-13/A2.
If you don't have an Assembly Manual, you really need to pick one up.
To A Arm Flaps
