Cold idle issue
Old Dec 20, 2010 | 12:14 PM
jir591's Avatar
jir591
Default Cold idle issue
I have a 1966 BB. The car starts fine and the engine speed rises after start to about 1,300 rpm. I usually let it run a couple of minutes at that speed and then quickly press the accelerator to bring the speed down. However, at this point the idle drops to about 500 and stalls out (unless I keep my foot on the gas). So I try to drive it to warm it but for the first few miles the idle is still slow and sometimes the engine will die at a stop light. Once the car is warm the idle is at 800 or so and all is fine.
Is there an adjustment on the carb I can make? Thanks.
Old Dec 20, 2010 | 12:16 PM
midyearvette's Avatar
midyearvette
choke adjustment.....richer
Old Dec 20, 2010 | 12:24 PM
jir591's Avatar
jir591
I somewhat of a novice here. so try to be specific.
Old Dec 20, 2010 | 12:26 PM
MikeM's Avatar
MikeM
That and the fast idle speed sounds a little slow to me. Don't know what the book says but I believe it's about twice what he has, isn't it?
Old Dec 20, 2010 | 01:09 PM
JohnZ's Avatar
JohnZ
One of my "Tech Bench" columns is attached that explains how the fast idle system works.
File Type: pdf
Old Dec 21, 2010 | 10:49 AM
Kensmith's Avatar
Kensmith
I know the feeling. I have a 383 stroker with a new Holley street avenger 770. I have adjusted the choke and fast idle cam. But no matter what, the motor will not run good until it reaches at least 120 degrees. Then it runs like a rocket. So a long warm-up is the only way to get going. Not like the daily drivers, no warm-up necessary.
Old Dec 21, 2010 | 01:01 PM
toddalin's Avatar
toddalin
2,600 RPM sounds too fast for the fast idle. I use a solonoid to set mine (no choke), and have it set at ~1,250 and even that seems a bit fast.
Does anyone know what the stock fast idle should be on a 327/350 hp?
Old Dec 21, 2010 | 01:19 PM
JohnZ's Avatar
JohnZ
2000 rpm, per the Specs section in the back of the Chassis Service Manual.
Old Dec 21, 2010 | 01:29 PM
toddalin's Avatar
toddalin
Thanks,
I guess that my 1,250-1,300 is fine as it easily keeps the cold engine running.
Old Dec 21, 2010 | 01:42 PM
Kensmith's Avatar
Kensmith
Thanks,
That's where mine is set. Was at 1800 rpm but I felt that was too high so set it at about 1200-1300. Will stay there until warmed up and I kick it down.
To Cold idle issue
