Speedometer Cable Replacement
Old Apr 8, 2002 | 08:30 PM
Shutter Man's Avatar
Shutter Man
Navigator
Default Speedometer Cable Replacement
On my '60, the speedometer cable is jumping around like crazy at low speeds. I ordered a replacement and looked under the dash to see what it takes to replace. Do you have to take the instrument cluster off to get at the speedometer connection or is there an easier way around this problem?
Looks pretty tight up there. Tach cable is visible, but the speed cable is mostly hidden...... What do you think?
Shutter Man
Old Apr 8, 2002 | 08:36 PM
62fuelie's Avatar
62fuelie
Default Re: Speedometer Cable Replacement (Shutter Man)
I won't say it can't be done, but if I had to change one I'd loosen the bolts and slide the cluster forward a couple of inches. You have to be careful not to scratch the paint on the t/s housing. Tape some thin cardboard over it to protect it.
Old Apr 8, 2002 | 11:05 PM
GTs 58's Avatar
GTs 58
Default Re: Speedometer Cable Replacement (62fuelie)
I have taken mine loose many times with the cluster inplace. A pita, but it can be done. :D
Old Apr 8, 2002 | 11:43 PM
62fuelie's Avatar
62fuelie
Default Re: Speedometer Cable Replacement (GT's58)
I can get one off pretty easily with the cluster in place. Same for tach cable. Getting it back on requires that I hold my mouth just right. :D
Old Apr 9, 2002 | 12:33 AM
GTs 58's Avatar
GTs 58
I have that stupid habit of chewing on my tongue when it gets oh so close to starting. :lol: ------------ :cheers:
Old Apr 9, 2002 | 09:59 PM
62fuelie's Avatar
62fuelie
Been there, done that, etc. Not a favorite task. :D
To Speedometer Cable Replacement
