Side Pipes
Old Jan 2, 2011 | 12:16 PM
Jerry Morris's Avatar
Jerry Morris
Default Side Pipes
I have a small block 65 Coupe and I am considering side pipes. Any thoughts on pros and cons? Any issues on installation - rattles, etc? Also, where is the best place to purchase high quality pipes.
Thanks in advance for your help,
Jerry
Old Jan 2, 2011 | 12:26 PM
62Jeff's Avatar
62Jeff
Pro - Sound great
Con - But only for a while. Road trips may require ear plugs.
Pro - Look good (to me)
Con - Less efficient than an undercar exhaust, stealing horsepower
Old Jan 2, 2011 | 12:42 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I have had them on my '67 conv. for 37 years and love them. I wouldn't be without them on my car. The sound is deep and throaty since I have Hedman headers, and they make a statement. A complete set can be $$$$, so be prepared. Dennis
Old Jan 2, 2011 | 01:08 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Surround sound at its best and they look . Best option to have on these midyears imho.
Old Jan 2, 2011 | 01:14 PM
bb62's Avatar
bb62
I'm not a fan of side pipes on coupes:
1. The resonance on coupes will really bother you even after short drives.
2. Side pipes reduce the power output of your vehicles. The bends in the pipes are too sharp to prevent unnecessary backpressure.
3. To my ear, the off road exhaust sounds much better and will add to the power of your vehicle.
4. Side pipes look better on convertibles than coupes. A GM stylist explained to me that side pipes make coupes look taller by extending the eye to well below the bottom of the door. Taller looking sports cars look less aggressive and less visually ready to look prepped for road racing.
Old Jan 2, 2011 | 06:24 PM
Easy Rider 1's Avatar
Easy Rider 1
Its all a matter of taste as far as how it looks. I think your "stylist" is full of himself. Nothing looks better than a coupe with side pipes. The roadsters look good too, but not as good as the coupe.
Maybe thats why GM has made crappy looking cars lately. Too many "stylists" with no style
Old Jan 2, 2011 | 06:27 PM
Dicecal's Avatar
Dicecal
Would not have a Midyear without side pipes!!
Old Jan 2, 2011 | 06:36 PM
DansYellow66's Avatar
DansYellow66
"Rattles?" - You won't hear those anymore.
You will have to bend out of the way, or cut the rock panel brackets off and do some trimming of the fiberglass. It would be painful for me to cut metal or fiberglas on a nice car for sidepipes, even though it is possible to do so carefully, save the parts and go back later. With stock size pipes you could get by with bending the rocker panel brackets out of the way. I'm not sure you could do so with some of the non-stock, larger diameter sidepipes. I have difficulty believing you would see any HP loss on a stock, hydraulic cam 327 car. Maybe on a solid lifter motor. Bt, it will sound faster.
Old Jan 2, 2011 | 06:38 PM
John 66 Vette's Avatar
John 66 Vette
Pro. Loud
Con. Loud
Love the sound.
Old Jan 2, 2011 | 06:43 PM
Gimme1MoreC1's Avatar
Gimme1MoreC1
Agree with the power issue, but the styling? Really? Seems to me the fastback design makes the coupe look longer, so with this theory the Vert would REALLY seem tall. The rocker moldings are not much narrow than the side exhaust, so I don't agree with this particular GM stylist. As for sound, I think a crossover pipe is the cure. JMO
Old Jan 2, 2011 | 07:57 PM
FastEddy's Avatar
FastEddy
The sidepipes do sound better with headers...under both acceleration and deceleration - I couldn't keep my RPM's down after adding the side exit Headmans
The factory sidepipes do kick up dust pretty good since they face down so much - I eventually cut my tips off and had them welded on facing straight out - looks great, works much better, and sounds the same.
With 2" inch manifolds, the sleeve at the pipe to manifold connection that is meant to direct the exhaust past the joint, has an inside diameter is less than 1.5" !!! My 64 still managed to run 12's in the quarter this way with 350hp ZZ4 engine. I assume the 2.5's are a little better, but the headers really woke mine up as far as seat of the pants feel, but I never did get to revisit the track.
Old Jan 3, 2011 | 12:23 AM
Pilot Dan's Avatar
Pilot Dan
Side pipes on a Coupe, nothing finer!!!
Great sounding and noise is really not a factor since the restoration as the car is very well insulated now (including under the headliner and inside the doors. Pilot Dan
Old Jan 3, 2011 | 02:40 AM
Ron Champe's Avatar
Ron Champe
Pro.....they hear me coming before they see me.
Old Jan 3, 2011 | 08:48 AM
65mark's Avatar
65mark
Got em on my '65 and they sound great. Wouldn't have it any other way!!!!
Old Jan 3, 2011 | 01:32 PM
kskid's Avatar
kskid
I seen a set in the C2 parts section yesterday. Pipes and covers.
Old Jan 3, 2011 | 01:50 PM
740izo6's Avatar
740izo6
http://www.youtube.com/watch?v=KzpfdDS0CBo
orignal
http://www.youtube.com/watch?v=YGBarSuobnQ
allens
they are loud ...... but loud pipes save lives!
http://www.youtube.com/user/740iz06
the originals are hard to differentiate from the allens by ear
To Side Pipes
