Cleaning white walls
Recently purchased new tires and the white walls are orangey, dark, discolored. I have tried Soft Scrub and Brillo Pads to new use. Help! I just cannot get them WHITE. Any suggestions? Reply to usana11@aol.com
Greg
Greg
dcamick (05-18-2019)
2015 C2 of Year Finalist
Greg
Greg
In my experience, the discoloration you describe on NEW tires is a defect in the tire itself or a result of improper storage where the black part of another tire was in contact with the whitewall area. If so, you cannot correct it without replacement.
The best cleaners for whitewalls are Simple Green at 100% concentration followed by Westley's Bleach White. I'd soak them for 3-5 minutes with liberal quantities of Simple Green, then scrub vigorously with a stiff bristle handle brush and rinse immediately. Repeat 2-3 times until there are no visible stains. Then repeat the same procedure once with the Westley's to make the white really "pop". If this does not work, the tires are defective and you should seek remedy with the supplier
Often the browning or yellowing of whitewalls is because of the oils from the black part of the tire (behind the whitewall) by osmosis finding their way up and thru the whitewall itself.
Diamondback on there whitewall tires place a barrier between the black background before vulcanizing their whitewall to the tire ( think port-a-wall) and you will get an idea of their technology. Have had a set of them on our 300 B Chrysler for some 15 years and the whitewalls are still fine.
For cleaning, I use soapy SOS pads with Westley's for more extreme requirements. I suggest that you wear rubber gloves as these products can be very drying on your hands. Simple Green works pretty well also. As I remember, Diamondback at one time did not recommend Westley's, rather they preferred Simple Green like products.
Westley's can be hard on your mag/aluminum wheels. Rinse off quickly, never let it dry on the wheel. Also can damage the clear coat finish found on many wheels. Can leave staining on your concrete driveway, as it will bleach out dirty or gray areas and leave you with light bleached out sections.
Same opinion as many others... Westly's Bleche-Wite. Can find it at local auto parts stores. Goes on easy, wipe on, done. No scrubbing, very effective. Have used it for many years with no issues or problems. Wear gloves if you have a cut on your hand.
Bleach White as noted.....and a stiff bristle brush and hot water....repeat a few times as needed...dont let it sit on your wheels or hubcaps too long...its strong. On my '41 Buick, the wide whtes are older and really yellowed....on that one I did the bleach white and also used a very fine steel wool with the hot water....sometimes you gotta do it more frequently, especially on these older tires.
Your tires are so bad it probably doesn't matter but Diamondback Tires says this on the topic:
http://www.dbtires.com/ruins_whitewalls.html
Received 1,857 Likes
I talked to the Goodyear lab in Akron, and they said the brown would never come out, regardless of what I used on them. After a few more phone calls, Goodyear agreed to make me another set, and they told the store owner not to unwrap them or stack them unwrapped. They made another set (at no charge to me) and shipped them, and they were fine.
There's a reason whitewalls and lettered tires are wrapped in barrier paper.
With a car like that who needs white walls...
The simple green is acid base and the bleachwhite will also attack painted surfaces.They also will make the polish or chrome on most
rims dull.I me how I know !
Been there, done that. In 1996, I had Goodyear make me a set of yellow-lettered tires for my Grand Sport, and they shipped them to my local Goodyear store. The kid in the back unwrapped them and stacked them for installation the next day, and when I took the car in, the yellow on three of the four tires had turned brown from absorbing the oil in the black side of the tires stacked on them.
