Pilot Bushing Help!
Bill
If you use your camera's "macro" feature (little flower symbol), your close-up shots will be properly focused.
nevertheless, just take the old one out and put the new one in. if the hole in the end of the crank is oversized for whatever reason, just have a new one made, it doesn't have to be a 'sleeved' bronze/brass one; a machine shop can turn you one from a larger bushing or suitable material... no problem...
FWIW, all the bronze bushings i have found lately are slightly magnetic (i'm curious, please hold a magnet to your new one), so i would make sure that you gease the pilot bushing hole before putting the trans in.
Bill
so, i will use the 'magnetic' bronze version and still grease it. the grease will protect/lubricate regardless whether the pores are clogged.
i'm still curious as to whether the bushing supplied to him is magnetic.
Bill
Bill
But, let me explain more than a few things that makes this "oil or grease" thing an issue:
The original Oilite bushings were porous bronze (non-magnetic) that were especially impregnated with an oil. And no, just soaking a porous bronze bushing in oil does not work. The impregnation was done under vacuum and heat, so that as they cooled down, the oil would wick and be drawn inward. The pores of the bronze held the oil, and they had to be wrapped in a packaging (plastic, or at least waxed paper) that did not allow the oil to be wicked out (cardboard or regular paper would wick out the oil and the bushing is no longer oil impregnated). As long as the bushing you have is oily and was wrapped in plastic, and was non-magnetic, that is an original style (good) bushing, and should not be greased. Grease has "soaps" (the thickener that make it a grease), and these will block the pores in the porous bushing. A light film of motor oil on the input shaft is all that is needed for these bushings.
Some time long ago, they found that adding "some" iron (which is magnetic) to the mixture of bronze, would make a harder bushing, which would last longer, but "might" damage the trans input shaft once the lube was "gone". These bushings were still oil impregnated, and still had to be wrapped in plastic. They were still porous and still a type of Oilite bushing, and were a relatively "good" bushing (not ideal). Again, grease should not be used.
Note that the higher the magnetic attraction, the higher the iron content, and the harder the material (and potential for damaging the trans input shaft).
But, these porous bronze or mixture of bronze and iron bushings have lately been replaced with a non-oily and higher content iron (more magnetic) bushing, and they are just stuck in a cardboard box or wrapped in paper. Because they contain little or no oil, these must be greased. I recommend a high moly content grease. Left over cam (flat tappet) assembly lube would be ideal.
In other words, if the bushing you are going to use is oily (and packaged properly to prevent the wicking out of the oil), then no grease should be used (just a light film of motor oil is fine).
However, if there is no oil to begin with, then best add a good moly grease, and I would pack a small amount of extra grease in the depression in front of the bushing (but don't pack it completely full, since the grease may try to force the bushing back out - in other words, leave a little air pocket).
The best insurance for your pilot bushing, is to not "use it" often. The bushing / trans input shaft only sees a rotational differential when the clutch pedal is depressed, and the shifter is in gear (and the engine is rotating at a different speed than what that gear is transmitting to the drivetrain). Sitting at a stop light in gear with the clutch depressed is not doing the pilot bushing any good.
Further info as to how an Oilite (porous oil "saturated") bushing works, is that the oil would migrate to the rotational surface due to heat, and the more heat, the higher the flow of oil. Once the bushing cooled back down, the oil would be drawn back into the porous bushing.
Obviously a non-oily bushing relies only on the surface grease film, which is not as sustaining as is the oil from a porous bushing.
Hope this helps,
Plasticman
http://surfrainbow.com/Load_Product....oductCode=5822
appears to be oilite and is not magnetic, I just checked. I didn't look to see if they sold bushings in the proper size for a pilot, but it's worth a look.
It is very difficult to find a pure bronze oilite bushing. I can't see the advantage to having one without ferrous content, anyway, as long is the bushing is oil impregnated. There is one company that makes them, but the name escapes me.
Almost always, the auto trans cars had cranks machined the same way as manual trans cars, but there WAS a brief period when the rear of the crank was machined differently between the two. Dorman has a listing of all of their GM bushings, and the one for auto trans is slightly smaller in outside diameter because the hole in the crank is smaller. Don't remember the dimensions offhand, but THIS is the most common, standard ID and standard OD bushing used for Chevrolet V8 engines:
http//www.dormanproducts.com/p-11019-690-014.aspx
If there are advantage/disadvantages to a non-ferrous pilot bushing, I would like for someone to point them out to me.
DO NOT use grease on an oilite bushing. This will clog the pores. Use a light coat of motor oil when first installed.
