Trailing are rust removal
Old Jan 23, 2011 | 08:56 PM
KNIPPS's Avatar
KNIPPS
Default Trailing are rust removal
ok with the front end done, steering box,trans, rear end and engine rebuilt I am finally onto the trailing arms...I just bead blasted one of them and was amazed at what great shape it was in under the surface crud which brings me to my question....how do you get inside the arm...I plan on painting them once they are done being blasted but looking into the arm bothers me. Am I being to **** and should I just get what I can with the wire wheel and blaster or am I missing some ancient chinese secret to really get into the inside of the arm...thanks...Jim
Old Jan 23, 2011 | 09:07 PM
64 roach's Avatar
64 roach
I just left my frame in a acid bath for week (in and out) after I used a bore scope to look up the inside the frame and it looked like new metal, if I was doing the TA's I would have had then galvenised also, then put a sand blasted profile on them and powder coated (much more durable and will not rust with light paint chipping). good luck, yea I'm **** also
