Decoding Block Numbers/Letters
Old Jan 24, 2011 | 04:38 PM
jimbolew's Avatar
jimbolew
Default Decoding Block Numbers/Letters
First, let me say what a terrific resource this forum has been to a "newbie" like myself! Members are so knowledgable and willing to share info, ideas and experiences that help folks like myself from having to make a lot of unnecessary mistakes.
With that said, can someone help me "decode" this info on my block pad, just below the passenger's side cylinder head?
It appears to be "T1028JC", but the "1" might be an "I"? ( I know the "7103757" matches the #s in my VIN.)
Thanks,
Jimbolew
Old Jan 24, 2011 | 04:50 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Thanks,
Jimbolew
This page tells all:
http://corvette-world.com/corvette_1...tion_codes.php
The only "JC" engine suffix is for a '67 427ci (lucky you!)
The "T" in front stands for a Towanda built block.
Old Jan 25, 2011 | 01:51 PM
JohnZ's Avatar
JohnZ
Thanks,
Jimbolew
"T1028JC" is a '67 427/400hp assembled on October 28, 1966, at the Tonawanda engine plant (source of all big-block engines). The "I" character was almost always used instead of the "1" character (Engineering direction since 1957).
Old Jan 25, 2011 | 02:22 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
The only problem is, if you are a newbe can you tell if it is a restamp? That is one of the most restamped #'s out there, on a survey a few years ago there were 20% more responces then cars ever built with a 67 427-400HP and that is only the people that responded. Look close at your deck markings and stamps. Good Luck
Old Jan 25, 2011 | 02:46 PM
JohnZ's Avatar
JohnZ
Here's a known-original '67 427/400hp pad; yours should look similar to this one.
Old Jan 25, 2011 | 03:50 PM
Frankie the Fink
Army
Originally Posted by 65 Pro Vette
....Look close at your deck markings and stamps. Good Luck
He asked what the stamping denotes and John told him. Whether or not the stamping is original is the same old debate with only one or two real experts existing on the topic.
To Decoding Block Numbers/Letters
