Compression Ratio
Old Jan 26, 2011 | 08:02 PM
BillyTz06's Avatar
BillyTz06
Default Compression Ratio
Can anyone tell me what the compression ratio would be on a 350 engine with -12cc dished pistons, 70 cc combustion chamber Edelbrock Performer RPM heads, .041 thickness head gaskets.
Old Jan 26, 2011 | 08:24 PM
LB66383's Avatar
LB66383
http://www.csgnetwork.com/compcalc.html
Old Jan 26, 2011 | 09:52 PM
Scott Marzahl's Avatar
Scott Marzahl
Not enough only about 8.5, even with a .015" gasket you are still less than 9:1. Use some flat tops.
To Compression Ratio
