Tach Reading Low
Old Jan 28, 2011 | 07:33 PM
jtranger's Avatar
jtranger
Default Tach Reading Low
The tach on my '61 FI is reading low. When at idle it shows 500 RPM when it actually should be 1000 RPM. At 3000 RPM it should be 4000 RPM. Any idea's or anyone had this problem. The tach does not intermittently fluctuate and keeps the same low reading curve. I don't want to tear the dash out if I don't have to!
The problem has been going on for a year or so and I am finally getting caught up to deal with it. I know aside from the tach it could be the cable or dist cross shaft gear, but not sure how to go about it. Thanks
Old Jan 28, 2011 | 07:53 PM
GCD1962's Avatar
GCD1962
Only place it could be wrong is in the tach head itself. The cable & gerar either work or don't, won't make it fluctuate
Old Jan 28, 2011 | 07:56 PM
steersdad's Avatar
steersdad
Default tach error
Your mechanical tach works just like your speedometer.
The key components are the cable, a rotating magnet, an enclosure called a speed cup, a key part called a hair spring, and the needle/pointer.
1. the tach cable, powered by the distributor, spins at the same speed as the distributor shaft.
2.The cable spins a magnet around at the same speed inside the speed cup of the tach. The magnet rotates continually as the engine is running.
3.The spinning magnet creates eddy currents in the speed cup.
5.The eddy currents make the speed cup rotate as well in an attempt to catch up with the magnet. Remember that the magnet and the speed cup are not joined together—there's air in between them.
6.The hair spring tightens, restraining the speed cup so it can turn only a little way.
7.As the speed cup turns, it turns the pointer up the dial, indicating the engine speed
So, most likely, the hair spring is worn. The cable is either broken, or not. If not, you get no reading.
Check with one of the tach repair specialists if there is any possible adjustment. Personally, I always just swapped the tach. Not that big a job.
Old Jan 28, 2011 | 08:19 PM
Donald #31176's Avatar
Donald #31176
The tach head could be one that was used with tach driven generators whose speed is twice that of a distributor driven tach. If that is the case the head will need to be recalibrated for distributor drive or perhaps a speed adapter from a speedometer shop can be rigged between the distributor and tach head.
Old Jan 29, 2011 | 03:25 AM
jtranger's Avatar
jtranger
I believe the tach originally out of a non FI car and was driven by the generator. In this case where would I get the tach properly calibrated?
Old Jan 29, 2011 | 10:27 AM
Donald #31176
Most instrument restorers have the proper degaussing equipment to properly calibrate the head. A couple of resources are Joe Ray Corvette Parts in Arkansas and Corvette Specialties of MD .
To Tach Reading Low
