1966 dash pad replace
Old Jan 30, 2011 | 03:27 PM
prestige6's Avatar
prestige6
Default 1966 dash pad replace
How hard is it to replace the passenger side dash pad. What does it entail. Any info would be appreciated.. thanks
Old Jan 30, 2011 | 04:00 PM
66jack's Avatar
66jack
Take out the glove box.
Remove radio and possibly the clock.
Remove center console.
Remove side panel.
Remove CLIPS, 7 on each side.
Use a flat blade screwdriver to spread open and pull out.
To install use pliers to squeeze in place.
The hardest ones are by the clock and radio.
Here is a picture and price from one of the suppliers.
http://www.parts123.com/parts123/yb....rt~A2~cadefibB
Good luck
jack
Old Jan 30, 2011 | 04:12 PM
prestige6's Avatar
prestige6
Remove side panel.
Good luck
jack
Thanks sounds pretty simple...I don't want to put a new one in, I would like a survivor one in perfect condition,being the other one is perfect and my car is a survivor.. Know where I can get one without being raped???
Old Jan 30, 2011 | 04:22 PM
66jack's Avatar
66jack
NO i don't...post on the parts for sale section...someone might have one.
ask for pictures, CLOSEUPS so you can see a little better on what they are trying to sell.
jack
Old Jan 30, 2011 | 04:24 PM
prestige6's Avatar
prestige6
jack
Already did Thanks...
Old Jan 30, 2011 | 05:08 PM
62Jeff's Avatar
62Jeff
You'll want to look at DZVette's article on dealing with the clips that hold the dash pad in place
http://www.lbfun.com/warehouse/tech_...ip-Install.pdf
Old Jan 30, 2011 | 05:47 PM
Hitch's Avatar
Hitch
Just a side note about those clips. As others have said using a small screwdriver to open them up some works great then I have used a small set of e-clip pliers to spread them the rest of the way for removal.
Dave
Old Jan 31, 2011 | 03:19 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
Make sure when you find a pad it is a 65-65 pad 63-64 pads have a different grain.
To 1966 dash pad replace
