Master Clinder
Old Jan 31, 2011 | 07:49 PM
KS69Coupe's Avatar
KS69Coupe
Default Master Clinder
I have a '66 that has been in storage for a few months. I've noticed a very, very slow leak from the passenger side rear brake and a spot of brake fluid on the garage floor about the size of the end of a Q-Tip.
I have added 70 R3 brake fluid.
Could you tell me how full the master cylinder should be kept. Picture attached. Wondering if this is plenty or should I add more. Still working on fixing the leak so I don't have to keep adding brake fluid. Brakes work just fine.
Old Jan 31, 2011 | 07:53 PM
1snake's Avatar
1snake
Your fluid level is too low. I usually fill it to approx. 1/2" from the top. BTW, what is "70 R3 brake fluid"? Never heard of it.
Jim
Old Jan 31, 2011 | 08:06 PM
KS69Coupe's Avatar
KS69Coupe
Thank you for the reply.
Master cylinder cap is stamped "use only SAE 70 R3 brake fluid" on the top of the cadmium dichromate lid so that is what I asked for at Auto Zone. He looked up the information I gave him and made the recommendation.
Checked the stamp number of the bottom of the master cylinder and it does not appear to be numbers matching for a '66. Should be #2225032 and mine looks like #2539039 and some of the numbers are very hard to make out so I might be off a little - I was using a mirror.
Any help is appreciated.
Old Jan 31, 2011 | 08:09 PM
1snake's Avatar
1snake
That must be the old spec. # for DOT 3. Any DOT 3/4 should be compatible. Good luck on the leak.
Jim
Old Jan 31, 2011 | 09:19 PM
63split63's Avatar
63split63
Default Fix The Leak !
I would fix the leak . If you are using ordinary brake fluid and the leaked fluid finds its way to your paint you will be sorry.
Also with a single master cyl system you don't want to take any chances .
Bill Purdy
Old Jan 31, 2011 | 09:51 PM
Bill Irwin's Avatar
Bill Irwin
Your low on fluid & fix the leak. It ain't gonna stop, only get worse. Bill
Old Jan 31, 2011 | 10:52 PM
Avispa's Avatar
Avispa
The leak you're describing is very common for C2s and C3s that sit for a while with the brakes not used. After some time, the cup seals in the calipers relax and let fluid leak. They'll hold pressure just fine, but when they're unpressurized gravity pulls the fluid past the relaxed seals.
If you store yours for long intervals, make it a point to go out and stomp on the brakes every week or so and hold em for a few seconds. This tends to keep the seals from relaxing to the leak point. Corvette Doctor did this for me while my car was in his shop for 19 months while I got my motor issues worked out. Haven't needed to reseal the calipers.
Old Feb 1, 2011 | 09:08 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Brakes
Time for a rebuild. I would rebuild the calipers with an O-ring kit. If the car sits for any length of time, the O-rings are more forgiving. At the very least, I would pull the pads out to make sure that brake fluid has not leaked on them. If I drive the car, brakes and steering are areas I never put off fixing. Jerry
Old Feb 1, 2011 | 09:53 AM
63split63's Avatar
63split63
Default O Ring Seals
Before you use o ring pistons in your calipers take the time to reserch the pros & cons . There is lots of info on this forum .
I just rebult my callipers and I chose not to use the O ring seals after doing a lot of reading .
Bill Purdy
Old Feb 1, 2011 | 03:18 PM
LB66383's Avatar
LB66383
I recently had a caliper that wasn't leaking, but it was sucking air in. Rebuilt it with a standard lip-seal kit from NAPA. Those work just fine.....if your calipers are stainless steel sleeved. If not, get some that are.......
Old Feb 1, 2011 | 06:22 PM
KS69Coupe's Avatar
KS69Coupe
Follow-up: SAE 70 R3 is the same as today's Super Heavy-Duty DOT 3 for manual drum and disc brakes found at local auto parts stores, according to my car guy at Auto Zone.
Good advice on fix the leak. Especially like the idea of just going out in the garage and mashing on the brakes to keep the seals active and pressurized. Like the idea of sitting in the car for a little while, pressurizing the brakes, and dreaming for warmer weather.
Thank all, will proceed to rebuild and stop the leak. Will have to investigate the O-Ring and stainless sleeve options.
Kevin
Old Feb 1, 2011 | 06:40 PM
1snake's Avatar
1snake
Bill Purdy
Do you have any specific info? I searched the C1/C2 and C3 sections here and a general Google search and found only positive comments on O-rings.
Jim
Old Feb 4, 2011 | 07:32 PM
KS69Coupe's Avatar
KS69Coupe
Hello All,
Have ordered the lip seal rebuild kit. Also ordered the DOT 5 synthetic brake fluid from CC and I'll go ahead and rebuild all 4 breaks and change to the synthetic at the same time. Will be nice to fix the leak and not have to worry about getting the DOT 3 on the paint.
Have no specifics to share on stainless sleeves versus o-rings versus lip seal. Just decided to go with the lip seal for $25.90 (all 4 brakes) plus shipping and handling + the synthetic brake fluid.
Thanks everyone
Kevin
Old Feb 5, 2011 | 01:25 PM
boxster99t's Avatar
boxster99t
Originally Posted by KS69Coupe
Hello All,
Thanks everyone
Kevin
Synthetic mixed with DOT 3/4 may create a sludge/mess in your brake system.
When you change over the fluid, make sure you thoroughly purge all remaining DOT 3/4 fluid from the Master Cylinder and brake lines.
I've seen many folks recommend disassembling the MC and calipers (even if all new parts), cleaning out the brake fluid (which is usually DOT 3/4) that was used in the assembly process for lubrication and applying a film of DOT 5, and flushing the brake lines assuming you're not replacing the brake lines (replacing brake lines with the body on is do-able but not the easiest job).
Or just use DOT 4 but change it every couple of years, like you should (but most folks never do).
To Master Clinder
