I have a slightly wallowed out upper control arm on the passenger side. My alignment guy showed me the slight left-to-right movement at the rear upper inner shaft as he exercised the suspension. I have a new control arm and both inner and outer shafts/bushings.
How hard is this to replace ?
Something I can do in my garage with typical hand tools and jack stands ?? I guess I'll need a spring compressor ? Right ?
I have 1/2" drive sockets, breaker bars, pickle fork but no compressed air or heavy-duty front end tools...
Frank,
You can do it with what you have. I'd use a threaded rod for the spring removal, given the space you have. The service manual has pretty good instructions. I've done a million of them (or so).......give me a call if you get stuck.
No need for a pickle fork or a spring compressor.
Placing a hydraulic floor jack under the lower a-arm and holding the whole assembly together until you have the lower inner removed allows you to ease the spring down with the jack. If the improper movement is in the a-arm itself, that is easy. If it's in the uper inner control arm or the crossmember, that's a different story. If you need an upper a-arm, I probably have a couple around.
Regards,
Mike Ernst
Reason: add
This is the hole where the left-to-right movement is occurring...its not dramatic but certainly noticeable!
Mike - as always thanks....once the parts come in I'll prob be calling you!
Jim - I'll search for the Tom posting....I hate doing front end work ever since I had a '66 Mustang spring become uncompressed all at once 10 years or so ago...it was lucky I didn't get nailed by it.
When you say you have new cross shafts and bushings, I assume you mean new that still needs to go in the car.
You probably don't need to change the control arm at all, just the shafts and bushings, but as longa syou ahve it, go for it.
I also assume you are going to do both sides. This is a very good time to get your components powder coated, if they aren't already. (I am good at spending other peoples money)
I don't recall if the inner upper shaft can be changed with the front cross member in the car.
BTW, a piece of 1/2" allthread put through the spring where the shock would go, with washers and nuts on both ends, it a good safe way to untension a spring.
If the crossmember has to come out the car will be driven like it is - I'm not up for that.
One old mechanic told me I could weld a spot on the arm to limit the play and that happened quite often "back in the day"....not the way I prefer to deal with things tho...
I don't think you need to worry about the spring. Just support the lower control arm with your floor jack. The upper arm can then be removed. It doesn't carry any spring load.
From: The problem is all inside your head she said to me.
Not so sure about no spring load. Look at the pictures. The upper is still connected to the kig pin and that's attached to the lower with the spring pushing on it. That is a beautiful write up Tom did . I have done the front end 15 years ago and those pictures bring it all back. It's amazing how crude the front end is.
Frank,
I know that this sounds bad coming from me.....but, I've actually done that on a couple of cars, and it works pretty well. The wear (movement) usually comes from the outside of the bushing to the control arm, as there is a very fine "thread" in those things. I've also welded a "sized" washer to the outside of the control arm (basically the same thing as the repair kit that CC sells, to re-establish the thread. The tack welds are almost invisible, and really don't have any stress on them, and will eliminate ALL of the play. I'm just sayin'.
I had that dilemma 15 years ago. The old Bubba fix was to tack weld the shaft to the crossmember. That fix was good for 10 feet or 10 seconds which ever came first. In my case I found an old 53 Chevy crossmember that had very little wear that I substituted for the original. Most venders sell the threaded bushings for the inner shaft but the crossmember will have to come out in order to fit the bushings properly so that the shaft aligns.
Frank,
I know that this sounds bad coming from me.....but, I've actually done that on a couple of cars, and it works pretty well. The wear (movement) usually comes from the outside of the bushing to the control arm, as there is a very fine "thread" in those things.....
Mike
That is exactly what the front end guy said. Ole' Malone Trawick over in Winter Garden said...he's been doing these cars, and all others, for 40+ years.
