Still stuck ignition tumbler
in my car. I really did not need to take it out. I was just going to replace all the bezels. I had the wiper one out because I was doing the SPW wiper kit. So far I like what I see with this kit. Seems to work smooth. Only time I've ever had two wipers working at the same time It's not that bad of an install, but it's no joy either. It's like typical wiper work. It sure cleans up under the dash. Nothing under there now but a tube. The tube from the drivers transmission down to where I mounted the motor(drivers kick panel) was the harder one to figure out and install.
Tried to get the tumbler out a few times again today. It really does not seem to want to come out. Maybe one day it will. I've jiggled it WD40'ed it wiggle and jiggle it just does not pop out.
My mopar M/C came but it was the 101323 not the 101323M the box was marked M but it was the non M version. Summit emailed me the UPS no problem. Now I just have to wait for it to come back. Ruins any chance of doing the Mill work this w/e.
St. Jude Donor '07
if you have to drill out the key cylinder, here's where to drill (no damage to the switch itself)
Bill
Bill maybe I could have gotten the M/C local, but sometimes it's more of a pain.
I also just took a second look at corvette central and found the tumbler. First time I looked I did not see it. I may drill it out now.
Mine did the same thing about a year ago, there's small rectangular piece of metal that protrudes from the tumbler and is retracted when the key is turned. Mine no longer retracted and I had to force it out with a screw driver. Bought all new correct parts. Pretty easy install. Luckily, Bubba had been there before so none of the parts were original.
Thanks Bill I'll look it up. The Corvette Central tumbler in the picture does not look like the one you drilled our or mine. It looks flat and does not have the ears. Maybe the picture is just a stock photo or the winged tumbler is for 60 and up. But since I've grown up around my fathers 60 I've only seen winged tumblers.
St. Jude Donor '07
Bill
