condenser looking thing
Old Feb 15, 2011 | 04:01 PM
bluzrocker's Avatar
bluzrocker
Default condenser looking thing
I have a 67 BB and while under the dash just behind the oil pressure gauge (mounted to the lower dash frame)
there is a round condenser looking thing w/ a single wire coming out of it...it is round 1" 1/4 long and5/8" dia..the wire is out of this thing and trying to IDENTIFY electrial looking thing??
any clues???
Bluzrocker
Old Feb 15, 2011 | 04:06 PM
vettedreamer50's Avatar
vettedreamer50
I speak your language, therefore I cant help you. lol Im sure someone here will know.
Old Feb 15, 2011 | 04:15 PM
bluzrocker's Avatar
bluzrocker
atta boy trust in the system...ehhh? ok
Tx.
.Bluzrocker
Old Feb 15, 2011 | 04:21 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
its a radio noise capacitor. look in your AIM under UPC U69. you will see all of them and were they go. IMHO you really don't need them unless you are going 100% original stock
Old Feb 15, 2011 | 04:24 PM
INMYBLOOD's Avatar
INMYBLOOD
From: The problem is all inside your head she said to me.
I was trying to look it up. My car has one.
condenser looking thingie
Old Feb 15, 2011 | 04:30 PM
bluzrocker's Avatar
bluzrocker
well yiu guy's have solved my problem in less than 45 min...next round on me...
Thanks for the detective work...the forum is a great place..
Bluzrocker
Old Feb 15, 2011 | 04:33 PM
John McGraw's Avatar
John McGraw
It's purpose was to absorb the spike voltage from opening contacts, which makes for radio noise. This was particularly a problem on AM radios and is not so much of an issue with FM. Early cars had capacitors all over the car to minimize this interference. They were across the coil, the generator, the voltage regulator, and brake light switch. They also grounded almost every part that was not solidly attached to the frame with ground straps to minimize the interference. This even included the ignition shielding and the little static dissipaters in the front wheel bearings, that almost no cars have anymore. Cars that were not supplied with radios had none of the shielding or ground straps.
Regards, John McGraw
Old Feb 15, 2011 | 10:37 PM
landshark 454's Avatar
landshark 454
I still have my wheel bearing static coils.
Old Feb 15, 2011 | 10:44 PM
gwalker's Avatar
gwalker
Don't throw it away, they are worth $$$.
To condenser looking thing
