I just purchased a SBC Grant Spalding tack drive Flamethrower distributor. It is missing the drive shaft/gear that goes inside adapter where the cable screws onto. Sure looks like Grant/Spalding used GM Corvette distributor parts, where can a guy buy a drive gear shaft? Anyone have a good pic of what I am looking for? The proper name would also help! Thanks, Lon
Here is the TACH DRIVE CROSS GEAR ASSEMBLY https://www.paragoncorvette.com/p-35...-assembly.aspx
Paragon Number: 367
GM Part Number:
Tach drive cross gear assembly w/roller bearing. These assemblies have much lower friction, hence longer life. S/S coupling. $75
Years: 1962 - 1974
