Sun Visor falling down gradually.
Old Feb 19, 2011 | 04:53 PM
zpletcher's Avatar
zpletcher
Default Sun Visor falling down gradually.
Does anyone know how to keep the driver's side visor from easing down
when driving. I have new visors and hardware, but the darn thing on
the driver's side won't tighten down any further!!
Cheers, Zale
Old Feb 19, 2011 | 05:26 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
On mine I ground a couple of flat spots at the angle I wanted the visors to stay at. The problem with that is it only has 2 positions it wants to stay at. If I put them at a different angle, it eventually slips back to the flat spots. The good thing is I rarley use them anyway and they now stay up where I put them.
Old Feb 19, 2011 | 05:52 PM
Stingray1967's Avatar
Stingray1967
There is a pin that slides into a metal sleeve inside the top part of the visor. I took the visor down (two screws, one at either end) so I could work on it. Then I took a pair of flat pliers (that is to say, not much teeth on the inside), wrapped the pliers with a few rounds of tape, and crushed the sleeve a little bit (doesn't take much).
That seems to have fixed it.
Old Feb 19, 2011 | 07:56 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
There is a torque and process for adjusting the tension of the "sunshade" in the assembly manual. For a '67, it's UPC 1, sheet E5.
Old Feb 20, 2011 | 01:53 AM
zpletcher's Avatar
zpletcher
Thanks Amigos...
I will try some of these ideas!
Cheers, Zale
Old Feb 20, 2011 | 08:57 AM
Mike Geary's Avatar
Mike Geary
Default another solution
put a layer of shrink sleeving on the pivot pin.
To Sun Visor falling down gradually.
