1959 Steering Box
Old Feb 19, 2011 | 11:39 PM
GEBackbone's Avatar
GEBackbone
Default 1959 Steering Box
I have a 1959 and there is a lot of play in my steering wheel. I adjusted it a while back and believe it's time for a new one. Does anyone have an idea as to where I could get a new or rebuilt one and also any tips would be greatly appreciated.
Thanks in advance, Gary
Old Feb 19, 2011 | 11:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
have your original one rebuilt. there are many places that offer to do that. one of the more popular places is http://www.bairs.com/
Old Feb 20, 2011 | 12:07 AM
1snake's Avatar
1snake
Bairs only does 63 + up. Parts for 53-62 boxes are hard to find and very few vendors rebuild them.
Jim
Old Feb 20, 2011 | 12:45 AM
K2's Avatar
K2
It is likely that the box needs to be rebuilt but before you do that I recommend you check and correct if necessary a few other possible sources of steering play.
1) Tie rod ends
2) drag link
3) wheel bearings
4) center arm bearing
An accumulation of tolerance in a combination of some or all of these can cause a lot of free play. After you have checked those and corrected any you find out of tolerance, then adjust your steering gear per the "ST-12" manual. If you still have objectionable play in the steering then its time to rebuild the steering box.
I believe Corvette Central still carries the gears, bearings, and seals to do the job.
Old Feb 20, 2011 | 06:39 AM
MaineDoc's Avatar
MaineDoc
Another direction might be to check out Hemmings for those vendors who service 49-54 Chevrolets.
Old Feb 20, 2011 | 07:33 AM
Pierre's Avatar
Pierre
Try these people:
http://www.corvettesteering.com/
Pierre
Old Feb 20, 2011 | 08:35 AM
Audiophobe's Avatar
Audiophobe
Originally Posted by Pierre
Try these people:
Pierre
Still looks like they don't deal with C1's unless I read it wrong.
Old Feb 20, 2011 | 08:59 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Originally Posted by GEBackbone
..... I adjusted it a while back and believe it's time for a new one....
That may have been your demise. I asked the old (REALLY, old) mechanic that aligns my car if he could adjust mine and he said, "of course, but my advice is to leave it alone" after spitting out a wad of chewing tobacco.
He launched into a long explanation as to how when the parts are worn and the adjustment is tightened up after decades of use it actually accelerates the wear. Not sure if I understood the theory but I am leaving mine alone.
Old Feb 20, 2011 | 09:01 AM
BobT59's Avatar
BobT59
I will be watching the respones as I also have the same question for my '59.
Old Feb 20, 2011 | 09:03 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Frank
if it's adjusted properly (as in not over-adjusted...), i can't see any harm being done.
Bill
Old Feb 20, 2011 | 09:07 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
JEEEEEEEEEEEEEEEEEEEEEEEEZE!!!!!!!!!!!!! !!!!!!!!!!
The 53-62 steering box is far and above the easiest to adjust as well as the easiest to rebuild if necessary. The aftermarket sources (Paragon, Corvette Central, etc) have have rebuild kits available. The ST-12 (WHAT, YOU DON'T HAVE ONE??????????????) has good instructions for doing the adjustment (the ST-12 is also available from the Corvette sources) and I've posted this multiple times.
First, there is no reason for having a sloppy steering box, and second, cut out the whining!
http://www.chevytalk.org/fusionbb/sh...hp?tid/225413/
Tom Parsons
Old Feb 20, 2011 | 12:10 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Basically, yes.
The hardest part is taking off and reinstalling the hood to the box and column out.
Doug
Old Feb 20, 2011 | 07:02 PM
GEBackbone's Avatar
GEBackbone
This is fantastic.. today I adjusted the steering gear box, this time following the ST-12 manual to the tee. When I got to step 4 on page 9-3, I found the locking nut was about to fall off and the worm bearing adjuster was way backed out. I ended up having to turn it in CW about 2 turns. I used a fish scale in place of the other scale and dialed it in. I was literally moments from buying a rebuild kit (in preperation for my next set of days off) before I read the replies and adjusted it properly. I have lived with this slop for about 5 years now. I guess my big lesson is, when all else fails follow intructions..I did a test drive and it's all good. I wish I would have done this years ago. Thanks again for the replies, always appreciated!
Gary
Old Feb 20, 2011 | 07:31 PM
silver67's Avatar
silver67
Gary
Did you fill the box with grease? I made a plug with a zerk fitting and filled it with synthetic grease. Did you adjust your drag link also? I had to rebuild mine with the tar "old grease" that was in it and a broken spring also.
To 1959 Steering Box
