I just completed a 283 for my 61. When I went to install the pilot bushing it wouldn't go in. I checked the ID of the crank hole and it is .030" smaller than another crank I have.
I purchased a reground kit with the proper casting number. I could machine the OD of the bushing to fit, but I am concerned about the hole in the crank being centered.
Did GM make a different crank for an automatic and std.? I didn't think they did. To say the least I was a little cranky! :mad
I wanted to get it back in the car today.
While they used the same cranks for automatics and manual trans during each model year, there were two pilot bushing sizes from different model years that are that are very close in O.D. It sounds like you have the smaller size crank hole.
A good auto supply house can sell you the right bushing.
Yeah, back in the day, I'd always heard that there was one for the 'standards' and one for the conversion from auto to standard. Dorman makes or made both. Probably like Jerry said, just a different year thing. Its been a LONG time since I change a PowerGlide car to a standard.
Be glad there was a hole at all. In the 50's & 60's, engines were built specifically for the trans being used. I have had many old cranks machined for a pilot bushing because the auto trans cranks had NO hole for the bushing. They had an unmachined indentation.
