Cranking Compression
Old Mar 22, 2011 | 05:07 PM
65silververt's Avatar
65silververt
Default Cranking Compression
What should the cranking compression be/cylinder for a stock 1966 427/390hp engine?
Old Mar 22, 2011 | 08:14 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
160 psi.
Gerry
Old Mar 22, 2011 | 09:57 PM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
but more important is that all cylinders are the same + or - 5lbs
Old Mar 22, 2011 | 10:12 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
That would be best. The book says maximum of 20lbs between cylinders. Otherwise " It is essential that improper compression be corrected before proceeding with an engine tune-up."
Gerry
Old Mar 22, 2011 | 10:49 PM
65silververt
Im trying to see if a cam is not advanced enough because the power is low after a recent rebuild-cam was apparently installed straight up without being degreed. I was told by a person to check the cranking compression and if the cranking compression was low, that it would indicate if the cam was too retarded. however, i was not given a specific PSI that would be considered too low or too high. I read online in an article that 160psi was low and that 220 was high. I guess it really just depends on the particular engine and its components and that is why i asked here. This engine was a stock 427/390 rebuild with the stock compression ratio.
Old Mar 22, 2011 | 11:39 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
Remember that they weren't degreed from the Factory, either. Stick with those specs for compression.
Old Mar 22, 2011 | 11:43 PM
65silververt
True, but this particular car should have much more power. Something isnt right.
Old Mar 23, 2011 | 01:33 AM
kskid's Avatar
kskid
If the cam was put in with the gear dots lined up on a stock engine, you should be good. Hope all the head bolts were torqued in the right order.
Old Mar 23, 2011 | 09:22 AM
midyearvette's Avatar
midyearvette
are you holding the throttle open while cranking for the compression check??
if it's running badly, i would first check the advance mech. in the dist. and also initial timing...jmo...
Old Mar 23, 2011 | 10:05 AM
Allcoupedup's Avatar
Allcoupedup
Not saying this happened to you but a common "no power after rebuild" issue is cam / static compression mismatch. After rebuilds many folks toss in big fat composition head gaskets and flat top pistons which brings down the compression ratio too much to work well with some of these old cams.
What was your MEASURED compression ratio?
Brian
Old Mar 23, 2011 | 10:47 AM
65silververt
Heads were ccd in right around 101 and the pistons used were the speed pro 16.8 forged pistons from speed pro, with a .038 thick gasket from felpro. The block has never been decked, so that should put it in the range of around 10.2:1 compression. That should be perfect for the stock cam, which wasnt very big.
I havent checked the cranking compression yet. Should the throttle be held open?
Old Mar 23, 2011 | 10:54 AM
Allcoupedup
Which Speed pro pistons did you use? Yes throttle should be held open so that you don't pull a vacuum on the intake stroke. Compression test should also be done with a warm engine and a fully charged battery.
Brian
Old Mar 23, 2011 | 11:30 AM
Donny Brass's Avatar
Donny Brass
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
shouldn't all the spark plugs be out, too ??
Old Mar 23, 2011 | 03:13 PM
Dan Hampton
Since they all have to be pulled, you might as well do it that way, as it will give the crank an optimal spin.
To Cranking Compression
