Tachometer Help
Old Mar 27, 2011 | 04:55 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Originally Posted by JohnZ
Yes, it does. 1000 rpm = 60 mph is the standard calibration for GM speedometers.
John, sorry for the temp hijacking of this thread.
You posted a link on the NCRS site regarding overheating. That link in your post has a virus. A bad one. As soon as I clicked the link. My anti virus software went off like crazy.. I couldnt log onto the NCRS site right away (Forgot my password).. So I thought I would get you here.
You may want to pull that link and investigate your computer. My anti virus software caught it.
If anyone gets a flag? Do a forced shutdown imediately.
DO NOT CLICK OR EXIT ANY BOXES.
FORCED SHUTDOWN ONLY.
Old Mar 27, 2011 | 05:21 PM
x0000rgw's Avatar
x0000rgw
Default Generator Tach?
Originally Posted by 64vert
Ray,
I replaced my bushing as you describe and the chatter is gone, at least while I am turning it with my drill. I still need to calibrate it, my drill speed is supposed to be 1200 RPM which would mean my tach needs to show 2400. I can't adjust it to get it that high, my next step is to verify that my drill is actually turning 1200, we have some industrial tachometers at work that I can use to do that.
Thanks,
Brian
Make sure that this is Not a generator drive tach. Generator
drive tachs show cable speed. 1200 RPM shows 1200 RPM on
the tach.
Ray
Old Mar 27, 2011 | 05:33 PM
62Jeff's Avatar
62Jeff
the tach.
Ray
No generator tachs after 61, his appears to be a 64.
Old Mar 27, 2011 | 06:19 PM
64vert's Avatar
64vert
I sold the 64, this is a 65 coupe, I guess I need to change my name
Old Mar 28, 2011 | 10:30 AM
x0000rgw's Avatar
x0000rgw
Default Swap meet tach
People buy old tachs at swap meets and don't know what
they are buying. A distributor tach is usually stamped on the
outside (tach shows twice cable speed). I have not seen
a generator drive tach that was stamped. However, I have
not seen that many.
Ray
Old Apr 1, 2011 | 05:21 PM
MiguelsC2's Avatar
MiguelsC2
Here is the cause of what I described above.
http://newenterprise.allthingsd.com/...mod=googlenews
Sorry for the hijack. It's important info.
Old Apr 2, 2011 | 01:12 PM
JohnZ's Avatar
JohnZ
I use the site I linked to in my post on the NCRS board every day (as do many others), and have never experienced what you did; the link you posted says it's not a Microsoft vulnerabililty, but it's a third-party program vulnerability - nobody else has reported it.
Old Apr 3, 2011 | 10:33 AM
64vert's Avatar
64vert
Ray,
Does this same ratio hold true for midyears?
Thanks,
Brian
Just as a heads up for anyone else doing this, I just verified my drill speed with a digital tachometer. For my particular drill (Porter Cable 18V), the max rotation is lower when rotating in the counterclockwise direction, which is the way the cable needs to rotate in this case. It is around 1050 instead of 1200, so I was able to get the tach calibrated ok. I replaced the worm gear in the speedo and got it to read correctly also.
I'm not sure if all drills are like this but it is worth checking out.
Thanks for the help,
Brian
