Had a valve job done before I put the motor back together. The guy I use is A#1. Bent a push rod first time out. changed it,no problem. Took it out Sunday to get Gas got on it started to miss.Same push rod bent. Pulled head,here's what I found. When they did the Valve job,the stem has 2 burrs in it,when it was cold it was ok.When it warmed up hung up in the guide,this is the result.He has retired since then,so I have to grin and bear it. Almost back together.This is one of the reasons I like to do all the work myself!!!
C1 of Year Finalist (appearance mods) 2019
One of the first things I learned when putting motors together was to first cycle the assembly by hand through a complete revolution of all cylinders, before putting gas and a match to it. So many things can be caught if you do!
i have seen this in the past when the stem to guide clearance is actually too tight on a new build from the start and that in turn would cause the burring which ultimately seizes the valve and it plays kissy face with a piston........
are you buying new heads or repairing what you have??.....
Exactly! especially with a high performance high lift cam. I put a thin layer of clay on top of each piston dome - then positioned the heads on the block, tightened the head bolts and hand cranked the motor over - then removed the heads after to see the clearances between each valve an piston.
No Surprises and no failures.
that is always good advice, however, if a guide seizes, claying the pistons won't help the situation.....
Frank, wouldn't you be able to feel a snug guide when you are fitting the valve into the head initially? They should all be feel the same right, and slide easily but not like a ho, more like a virgin, right?
hehehe!
boy! what an analogy!....
but yeah, youre right , it's all about being careful and using the proper stem to guide clearances especially on the exhaust valves........
If you have a new cam or have messed with the timing chain, I'd suspect the cam or cam timing. I have had that happen to me twice. the cam both times...
