Fyi
Given a compression ratio of 11.4 and a trapped compression ratio of 9.0, inlet temperature of 100F and inlet pressure of 1 Bar:
If the plug fires at -45 deg BTC the cylinder Temp will be 399F , Press will be 66psi
Required firing voltages at various gaps: .050" = 12.1kV, .080" = 18.1kV, .100" =22.1kV
If the plug fires at -35 deg BTC, the cylinder Temp will be 496F, Press will be 97psi
Required firing voltages at various gaps: .050" = 15.3kV, .080" = 23.2kV, .100" =28.3kV
If the plug fires at -25 deg BTC, the cylinder Temp will be 609F, Press will be 144psi
Required firing voltages at various gaps: .050" = 19.6kV, .080" = 29.8kV, .100" =36.5kV
As can be seen, larger gaps require higher firing voltages. But retarded ignition timing also requires higher firing voltages.
The worst scenario is a high compression engine, with large plug gaps and retarded ignition.
