Negative Amps
Old Apr 3, 2011 | 05:08 PM
Tinat's Avatar
Tinat
Default Negative Amps
Happy spring everyone. Yep, it's time for us folks to come out of hybernation and look at the car again. It's been a long winter.
Okay, just a quick reminder, we are working on a 1960 fuelie and have completely restored everything on the car.
The problem now is the amp meter is reading negative. We have checked the wiring (it is all new) and we have it hooked up "thanks to the beautiful colored pictures JohnZ sent" completely correct. What are we doing wrong.
Another problem......the horn relay doesn't work. Are these two related.
Under the dash, on the amp guage, we have 2 red wires and a condenser on the left and a black ground on the right.
Any help appreciated
Old Apr 3, 2011 | 05:37 PM
1snake's Avatar
1snake
With the engine off, which way does the needle move when you turn the lights on? That will tell you if it's wired correctly.
Jim
Old Apr 3, 2011 | 05:54 PM
66jack's Avatar
66jack
Somebody, "who i cannot remember", mentioned on a different post, that the wires/plugged into the ammeter are on the wrong tangs.
per their wiring diagram....
jack
Old Apr 3, 2011 | 06:43 PM
MikeM's Avatar
MikeM
Very likely! Check your connections.
Old Apr 4, 2011 | 08:49 AM
mashinter's Avatar
mashinter
Be careful...the black wire is the primary 12 ga. 12V feed from the battery. It should be on the ammeter terminal away from the oil gauge.
Old Apr 4, 2011 | 02:08 PM
mashinter's Avatar
mashinter
There are 4 red wires (2 wires in each of 2 lugs) coming off the back of my '59 ammeter:
A 12 ga. runs to the voltage regulator.
A 14 ga. runs to the ignition switch.
A 16 ga. runs to the lighter.
A 12 ga. feeds the horn relay, light switch and clock. If your clock and lights work, there may be a problem where the wires are spliced together.
Old Apr 4, 2011 | 02:17 PM
JohnZ's Avatar
JohnZ
The black wire (main feed from the starter solenoid battery cable stud) should be on the ammeter terminal closest to the driver's door, and the red wires should be on the terminal closest to the passenger door (the factory '58-'62 wiring diagrams are reversed).
Old Apr 4, 2011 | 03:45 PM
jafranke's Avatar
jafranke
jack
Yep....the drawing is wrong....they were wrong on the original in the AIM and everyone who does a re-print replicates the mistake. It seems to come up every now and then on the forum. I consider it a sign of someone that actually restored their own car when they ask the question...
Jon
Old Apr 4, 2011 | 08:53 PM
Tinat's Avatar
Tinat
I got that right to begin with, thanks to you John and the pictures you sent.
Old Apr 4, 2011 | 08:55 PM
Tinat's Avatar
Tinat
Jim
I will try this tomorrow
To Negative Amps
