67 tranny reverse switch
Old Apr 6, 2011 | 06:27 AM
vetter61's Avatar
vetter61
Default 67 tranny reverse switch
Is anyone repairing wires on switch. My switch works fine but brittle wires have broken off.
Old Apr 6, 2011 | 05:59 PM
John 66 Vette's Avatar
John 66 Vette
I have the same problem as you.
John
Old Apr 6, 2011 | 09:22 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
Just pick that tar-like stuff off the switch.
Than you can get into the switch to clean it up and fix it.
Goop it up with silicone when you have it put back together.
Sorry I can't be more detailed but it's been more than 10 years since I fixed my switch.
It was easy.
P.S. Should either of you gentlemen decide to get new switches, I could sure use the connector off an old backup light switch.
Old Apr 7, 2011 | 01:09 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
I had the same problem several years ago. I just soldered them back together.
If you can't do it, send it to me with postage paid both ways and I'll do it for you.
Old Apr 11, 2011 | 12:06 PM
vetter61's Avatar
vetter61
Default reverse switch
Wire connector on switch is broken off.
To 67 tranny reverse switch
