66 Posi Problem
Old Apr 8, 2011 | 10:03 AM
attyman1968's Avatar
attyman1968
Default 66 Posi Problem
I just bought a 1966 with a posi; however, I only have one tire hooking up. Lets start with the idea that I know nothing about positraction except what I have been reading here. I guess maybe its the clutches, but I don't know. Any help would be greatly appreciated. Thanks!!!! B
Old Apr 8, 2011 | 10:17 AM
landshark 454's Avatar
landshark 454
If it is truly a positraction, then the clutches are most likely shot, and the unit will have to come out.
Old Apr 8, 2011 | 10:25 AM
attyman1968
Its a big block posi. After my research, I was guessing it was most likely the clutches. Now I just have to find someone in south Alabama who can fix it. This is not my kind of project. Thanks!!
Old Apr 8, 2011 | 11:59 AM
5thvet's Avatar
5thvet
Contact Gary Ramadei. He is the best C2 rear rebuilder you'll find.
Gary.RAMADEI@radiall.com
Don
Old Apr 8, 2011 | 12:03 PM
attyman1968
Don
I have been reading about Gary, and reading his rebuild articles. Thats probably the way to go. I just wonder how long I will have the car out of service. Guess I need to shoot him an email. Thanks
Old Apr 8, 2011 | 12:06 PM
5thvet's Avatar
5thvet
Yeah, it depends on how busy he is but with him you know it will be done right. Shoot him a message, he is very prompt in getting back to you.
Old Apr 8, 2011 | 04:07 PM
Powershift's Avatar
Powershift
Don
BUT, if Gary can't get to it for a few weeks/months I would call Bair's in Pennsylvania. Besides Gary, they are the only one I would recommend. Their turnaround time should be short.
Larry
Old Apr 8, 2011 | 04:57 PM
redvetracr's Avatar
redvetracr
you might also contact Mike Dwyer /tracdogg2 he is a member here and does 1st class work also, I believe he is located near Dallas
Old Apr 8, 2011 | 08:55 PM
attyman1968
Larry
Thanks, but could you narrow that down for me some to a town or area in Pennsylvania.
Old Apr 8, 2011 | 08:58 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
Have you checked the codes on the rear?
It's possible you may have a perfectly functioning, non-posi unit.
Old Apr 8, 2011 | 09:05 PM
attyman1968
yes, its an FA.
Old Apr 9, 2011 | 02:16 PM
Ron Miller's Avatar
Ron Miller
http://www.bairs.com/
Old Apr 10, 2011 | 11:35 AM
tominohio's Avatar
tominohio
Originally Posted by Ron Miller
Before all the down time and expense I am have a trick that works on this issue about 70% of the time.
1) Drain the posi unit and refill with Type-F transmission fluid.
2) Take the car for a brisk run through the gears no more than about
5 miles total. The trans fluid will have taken any glaze off the
plates by then.
3) Drain and refill with the correct GM lube and posi additive. I bet in
most cases your problem will be over.
Tom in Ohio
Old Apr 10, 2011 | 11:50 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
plates by then.
Tom in Ohio
Old Apr 11, 2011 | 09:35 AM
attyman1968
plates by then.
Tom in Ohio
well that I will try this week. Thanks!!!!!
To 66 Posi Problem
