running a engine on a test stand voltage question
Old Apr 8, 2011 | 09:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default running a engine on a test stand voltage question
the engine builder doing the engine for my Chevelle has my engine running on his test stand using his HEI Distributor. but he said in order to run my stock points distributor he needs to modify his test stand wiring to get only 6 volts to the distributor and coil. is that right
but the good news is he had it running for a hour tonight with no problems
Old Apr 8, 2011 | 10:07 PM
landshark 454's Avatar
landshark 454
just get a ballast resistor, and hook 12 volts to it, and then hook it to your coil.
Old Apr 9, 2011 | 11:41 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Keith,
Were rooting for you. Dennis
Old Apr 9, 2011 | 11:43 AM
5thvet's Avatar
5thvet
Best of luck with this rebuild!!!
Old Apr 9, 2011 | 12:47 PM
street62's Avatar
street62
You do not have to lower the voltage just to run it on the test stand. when you turn the key to the start position the engine gets 12 volts then when it starts and you let go of the key it drops down to about 8 volts, thru the ballast resister. If you run it on 12 volts all the time it will just kill the pionts.
To running a engine on a test stand voltage question
