No dash lights
Old Apr 10, 2011 | 11:10 AM
INMYBLOOD's Avatar
INMYBLOOD
From: The problem is all inside your head she said to me.
Default No dash lights
What usually causes this? I recently put in a new wiper system and A/C. What may have happened is this. When I went to put my radio back in I accidentally Hooked hot to hot and ground to hot, so I put 12 in the ground circuit. Got the ground wire hot, coming from a harness to ground behind the console. Could I have burned out the light switch? Head lights and everything else in the car works.
Old Apr 10, 2011 | 11:20 AM
62Jeff's Avatar
62Jeff
What year car? I know you said A/C but that could be aftermarket A/C in a straight axle.
1) Check the fuse. If you have a 63-67 I know there's a dedicated fuse for the Panel Lamps
2) Check the headlight switch - are you sure you don't have the **** turned to the "dim" setting?
Jeff
Old Apr 11, 2011 | 06:41 AM
INMYBLOOD's Avatar
INMYBLOOD
Jeff
1958 yes I've taken a quick look at the fuses, turned the dimmer. That's what I'm wonder about. The switch?
Old Apr 12, 2011 | 09:36 PM
aupaul's Avatar
aupaul
I had no instr. panel light on my 62. I ran a test cable fron + post of the Batt. and touched the bottom fuse. The light then worked. Removed headlight switch. Jumped red wire to grey and that worked. BAD HEADLIGHT SWITCH ON MINE.
To No dash lights
