Rear Grounding Point
Old Apr 12, 2011 | 06:23 PM
SherpaPilot's Avatar
SherpaPilot
Default Rear Grounding Point
Does anyone know where the rear wiring harness is grounded? My assembly manual shows the tail lights grounded to a body connector. Is there another ground aft of this connector? I searched the net as well as the forum stickys without luck.
Old Apr 12, 2011 | 06:44 PM
1snake's Avatar
1snake
Your rear harness is grounded through a single screw on the bottom of the dash cross brace just left of the radio.
Jim
Old Apr 12, 2011 | 06:50 PM
BLee's Avatar
BLee
Yep, not much of a ground but I'm guessing it made assembly much easier on the line. I ran a ground from each outboard tail light stud to a hole on the end of the frame just to make sure, a foot of wire and 4 ring connectors plus a couple of small bolts is all it takes and it's not visible. I've heard of too many gremlins that were attributed to bad grounds
Jim
To Rear Grounding Point
