rear control arm
Old Apr 14, 2011 | 02:15 PM
frankgv's Avatar
frankgv
Default rear control arm
Hello all, welcome to spring????
My question is, how to secure the slotted rear control arm shims.('64) I am missing one ( broke off??). Going to replace with a slotted shim but what keeps it in place. Anyone replaced this type? Please help
Thanks a lot,
Frank
Old Apr 14, 2011 | 02:27 PM
gbvette62's Avatar
gbvette62
The trailing arm shims are held in place by a large, 6" long, cotter pin.
64's didn't originally use the slotted shims. These were introduced around 1970. Prior to that, the shims had just 2 holes in them. Most people use the slotted ones now, as they are much easier to install.
Old Apr 14, 2011 | 04:10 PM
gbvette62's Avatar
gbvette62
Here's an illustration of the installation of the trailing arm shims and cotter pin. This is from a 74 assembly manual, but the install is the same.
Old Apr 14, 2011 | 04:21 PM
frankgv's Avatar
frankgv
AH,Thanks,
That makes sense now,probably have to drill a hole for any suitable pin to lock in the shim. I noticed the other shims are not tied together with anything,
hanks again,
Frank
To rear control arm
