Block question
Old Apr 15, 2011 | 09:41 PM
32361ARTHUR's Avatar
32361ARTHUR
Default Block question
What is a factory roller four bolt main block. That is what my 383 is made from and I have no idea what year or what these were in. What is a roller block? I never heard of one. Is there such a thing? I Imagine it could be out of the eighties but I figure one of you guys might give me an answer.
Old Apr 15, 2011 | 10:04 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
A roller block I think means that it uses roller cam followers or lifters. The old blocks used flat tappet lifters, and along the line they changed over to roller lifters. They have hardware in the lifter area that is designed to keep the roller lifters from turning and ruining the cam. You may have seen roller lifter kits made for older engines that have the link bar between each pair of lifters? Well the roller blocks have that all taken care of from the factory with what they call "spiders" I think. I don't know when they changed over though.
Gerry
Old Apr 16, 2011 | 12:52 AM
Smilie 388's Avatar
Smilie 388
the factory roller block is a 1 piece rear seal . First year was around 1987 or 1988 . It's hit or miss on the early(88-90) blocks if they're drilled for the roller cam . The 5.7 Vortec in my 97 pickup is factory roller cam . You have to watch as some have no provision for the mechanical fuel pump . The roller cam motors have less friction than a flat tappet to help with fuel economy .
Old Apr 16, 2011 | 03:09 AM
Westlotorn's Avatar
Westlotorn
Roller Camshafts also hang the valve full open faster with steeper Camshaft ramps giving more flow which translates to a power increase accross the whole power band. The only negative is the cost, they are expensive to buy parts for.
Old Apr 16, 2011 | 07:35 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
The first year for the 1-piece rear main seal on a SB was 86 and 91 for BBs.
Tom Parsons
66since71's Avatar
66since71
See edit note
Last edited by 66since71; Apr 16, 2011 at 07:44 AM. Reason: Didn't sound right so I checked and it wasn't
To Block question
