miss
Old May 3, 2011 | 10:31 PM
original76's Avatar
original76
Default miss
'66 327 350 hp started with slight miss. Slight miss has turned into back firing through the carburator. Where should I start?
Old May 3, 2011 | 10:36 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Most likley it's in the ignition system. Recheck your timing, initial, centrifigal, and vacuum, point set. Others here may give you more details. Dennis
Old May 3, 2011 | 10:53 PM
jesterdcv's Avatar
jesterdcv
I agree sounds like and ignition problem. When using your timing light ensure that there is a smooth increase in timing as engine rpm increases. There may be a stuck centrifugal weight or the vacuum advance may be sticking. Another check would be the distributer cap and rotor if there are carbon trails that could be the problem.
Old May 3, 2011 | 11:21 PM
landshark 454's Avatar
landshark 454
If it is a constant backfire, that increases in loudness when you accelerate, you have wiped an exhaust lobe on your camshaft. to locate the cylinder, remove one plug wire at a time from the cap, and jazz the throttle. The popping will reduce considerably when you hit the right cylinder. A lean condition will cause a single backfire combined with a lag, or hesitation. Ignition crossfire would be intermittent, and not continuous.
Old May 4, 2011 | 08:03 AM
MikeM's Avatar
MikeM
........or a pushrod/rocker arm is bent/broken. Broken intake valve spring too.
Old May 4, 2011 | 08:42 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Backfire
When you get the engine squared away, check the power valve in the Holley. They are known to take out a power valve as a result of a backfire through the carb. Jerry
Old May 4, 2011 | 09:09 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I had a couple of broken valve springs in a 427 that I had in my 66 Chevelle. I only had a miss in the engine. Never had the backfire. I didn't think about it at the time but both that broke must have been on the exhaust side. I went ahead and replaced all 16 anyway. At the time they had designed the new double spring unit with the dampener to cure the problem. I believe in 67 those springs had become standard for the 435's and L-88's. JohnZ will know that.
Old May 16, 2011 | 06:02 PM
original76's Avatar
original76
Thank you for your help. Turned out to be spark plug wires. However, I did check for timing chain jump and bent or broken valve train parts. Engine is running strong and ready for next road trip and repair lol.
Old May 16, 2011 | 06:42 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Backfiring in the tailpipe (often called 'afterfire') is raw gas detonating in a hot tailpipe. I had it sporadically back when I had faulty needle valves in the carbs which fouled my plugs horribly. However, all of the above suggestions apply -- although I haven't seen in a blown power valve in Holley carbs in many a year with the later versions...
To miss
