63 327 Engine Decode
Old May 14, 2011 | 01:21 PM
Gumpy's Avatar
Gumpy
Default 63 327 Engine Decode
Hi
new to forum here but on others on the internet....I would like to decode my engine.....numbers on front of block are....310819 F0925RE: can not see block numbers on rear at this time...thankyou GUMP
Old May 14, 2011 | 02:17 PM
5thvet's Avatar
5thvet
63 327 340HP SHP Manual trans, 4 barrel carb, dated Sept 25th. You seem to be missing a number on the VIN derivitive after the 31. Yours is either the 819th or 10819th made.
Old May 14, 2011 | 10:02 PM
Gumpy's Avatar
Gumpy
Default re-checked numbers 327 sph
rechecked the numbers and after the 31 is "0" or an "o' BUT IT LOOKS LIKE A ZERO TO ME.....anyone else pipe in......thankyou:
Old May 15, 2011 | 12:12 AM
5thvet's Avatar
5thvet
In the number sequence there should be 7 numbers. The first is a 3 for the year, the next is a 1 which really is a filler because there were never 100,000 made, the next 5 numbers would be the number yours was made in the sequence. If the number was say 3110819 yours would be the 10,819th made. If the numbers were 3100819, your would be the 819th made. You seem to be missing a number is what I am saying.
Don
Old May 15, 2011 | 12:19 AM
Gumpy's Avatar
Gumpy
I understand....iwoll check it one more time.... Just happy it is an original RE engine
Old May 15, 2011 | 12:36 AM
gold63's Avatar
gold63
Hi,
Is your '63 #819 a coupe or convertible?
What colors??
I like to record them and do not have this early '63 listed.
Syd
Old May 15, 2011 | 08:42 PM
bojangles's Avatar
bojangles
Gumpy...... My Vette was built on Oct 5, 1962 with a VIN of 1122. You may have an early production '63.
Old May 15, 2011 | 11:12 PM
jimgessner's Avatar
jimgessner
"Yours is either the 819th or 10819th made."
I bet 819, as the F0925= Engine assembly date, September 25, 1962, which fits the early October production time frame of this car.
Old May 16, 2011 | 10:52 AM
Gumpy's Avatar
Gumpy
thank you to all those responding......been restoring other types of cars...this is my first corvette....looks like a gem....took it out for a drive yesterday and surprised how much power it has!...are these camel hump heads? and did the RE code engine have solid lifters for super high performance 327? thank you
Old May 16, 2011 | 11:59 AM
redred65cpe's Avatar
redred65cpe
Yes, the 340hp motor had solid lifters. At the top is a FAQ section and in there is a thread for books and such that come in handy when owning a Corvette: http://forums.corvetteforum.com/c1-a...ese-books.html
Sounds like you got a nice car.
larry
Old Jun 7, 2011 | 12:27 AM
Gumpy's Avatar
Gumpy
came up with the head number.....3782461 K 10 1 ....is it possible to have 1961 heads on this engine? or am i reading them correct?
Old Jun 7, 2011 | 11:13 AM
jimgessner's Avatar
jimgessner
K 10 1= November 10, 1961 used in an early 1962 production 327 engine, with 300, 340 or 360hp ratings. Passenger car 300hp engines also used them.
Old Jun 7, 2011 | 08:51 PM
Gumpy's Avatar
Gumpy
Thank you Jim
Old Jun 8, 2011 | 10:19 PM
Gumpy's Avatar
Gumpy
transmission code came up T10-7D r-2 ,,,,t100-1 ,,,3813490
bell housing # 3858403do these numbers correspond with 1963 convertible thank you
Old Jun 9, 2011 | 12:22 AM
Gumpy's Avatar
Gumpy
Btt
Old Jun 9, 2011 | 11:08 AM
jimgessner's Avatar
jimgessner
Early 1963 Corvettes used the Borg-Warner T-10 style 4 speed that had been in use since 1957.
And yes, this 63 unit was a T10D-1 Maincase with a T10-7D Tailshaft, AND A T10-148B sidecover. It was alluminum.
The first Muncie 4 speed did not start production shippment until February 6, 1963, and started to show up in Corvette cars in May and June 1963. Passenger cars got the first round on Muncies
The vin number derative (3S10819) of your car will also be stamped on the side of the flange and a date code like WA2832 = Warner 4 sp, A=Jan, 3= year 1963, 28=day28,2=year,2 shift
Old Jun 9, 2011 | 11:44 AM
JohnZ's Avatar
JohnZ
63's used the 421 bellhousing, with the small hole to match the smaller-diameter front bearing retainer; if that one has a '63-only T10-1D main case and the later 403 bellhousing with the larger hole for the front bearing retainer, the front bearing retainer isn't positively registered to the bellhousing.
Old Jun 9, 2011 | 12:18 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
good catch John--
I've been down that road--it ain't pretty.
To 63 327 Engine Decode
