wcfb choke...
Old May 15, 2011 | 05:34 PM
knockbill's Avatar
knockbill
Default wcfb choke...
hi,,,
i'm trying to set up a wcfb carb,,, i can set teh choke so it is closed when teh engine is cold, but i can't get it to open as it warms up,,,, my thoughts,, choke thermo spring in backwards, or wrong spring....any thoughts out there?
thanks in advance,,
john
Old May 15, 2011 | 05:51 PM
midyearvette's Avatar
midyearvette
Originally Posted by knockbill
hi,,,
thanks in advance,,
john
is teh heat tube installed from teh exhaust manifold or is it controlled by another heat source to teh thermo coil??
Old May 15, 2011 | 05:55 PM
knockbill's Avatar
knockbill
it has a new tube and the piston and cylinder are clean...
Old May 15, 2011 | 06:05 PM
1snake's Avatar
1snake
Is there heat being drawn into the choke housing? If not, the vacuum source is plugged.
Jim
Old May 15, 2011 | 06:21 PM
knockbill's Avatar
knockbill
Jim
i don't know,,, how can i check ?
does teh piston open the choke as it warms up, and teh thermo spring push it close when it cools? if i open it manually as it warms up, teh therm spring closes it as it cools....
Old May 15, 2011 | 09:28 PM
1snake's Avatar
1snake
Feel the steel pipe where it enters the choke housing. It should get very hot. The spring tension in the coil closes the choke, engine vacuum tries to open it and when the coil gets hot, it loses its tension and vacuum wins, therefore fully opening the choke.
Jim
Old May 16, 2011 | 02:12 PM
rengawdor's Avatar
rengawdor
This manual gives a good description of how the entire choke system operates:
http://www.carbkitsource.com/carbs/t...fb-service.pdf
(Starting on page 9)
Good luck!
Rod
Old May 16, 2011 | 02:34 PM
66jack's Avatar
66jack
hi,,,
thanks in advance,,
john
Maybe the spring is not even on the "pin" to open and close the choke.
Old May 16, 2011 | 03:33 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Vacuum ???
Remove the heat tube from the carb. Start the engine and put your finger on the nipple that the choke tube screws onto. You should feel a slight amount of vacuum there. If not, you either have a clog somewhere or a vacuum leak in the choke housing (cracked housing, missing gasket, etc.)
RON
Old May 16, 2011 | 03:34 PM
Pilot Dan's Avatar
Pilot Dan
Good luck!
Rod
(Great manual link Rod, thanks) Take a look at the figure on p.11, it shows the proper orientation of the thermospring to the choke finger. Notice it is to the right of the finger. As the engine warms up, the spring expands (relaxes) and allows the choke to open fully with the aid of the vacuum piston pulling down.
Old May 16, 2011 | 03:56 PM
knockbill's Avatar
knockbill
Jim
thanks for teh reply.... if teh spring closes teh choke on cool down,,, then teh spring is installed properly.... that leaves teh piston/ vacuum side to look at...
tahnks again
john
Old May 16, 2011 | 04:00 PM
knockbill's Avatar
knockbill
Good luck!
Rod
thanks fro the reply.... i forgot i have that manual!!!!! its tough getting old.....
Old May 16, 2011 | 04:01 PM
knockbill's Avatar
knockbill
tahnks for the reply... it is, i mentioned,if i open it manually, teh spring will close it.
Old May 16, 2011 | 04:03 PM
knockbill's Avatar
knockbill
[QUOTE=rongold;1577630589]Remove the heat tube from the carb. Start the engine and put your finger on the nipple that the choke tube screws onto. You should feel a slight amount of vacuum there. If not, you either have a clog somewhere or a vacuum leak in the choke housing (cracked housing, missing gasket, etc.)
thanks for the reply....
good info,,, should it read on a vacuum gauge?
Old May 16, 2011 | 05:15 PM
65GGvert's Avatar
65GGvert
On a side note. I think the "e" and "h" are reversed on your keyboard.
Old May 16, 2011 | 06:14 PM
knockbill's Avatar
knockbill
i don't know... seems to be that way on any keyboard i use!!!!!!!!!!!!!!
Old May 16, 2011 | 07:41 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Sooooooooooooooooooooo, does that mean you don't proof read your comments before submitting?????
Tom Parsons
Old May 18, 2011 | 04:13 PM
knockbill's Avatar
knockbill
thanks to those that sent info ....
i started teh engine this morning, and it went right to fast idle, and the choke opened smoothly, in a few minutes,,,teh engine idled down, and the secondary lock out released,,,
To wcfb choke...
