66 Differential u-joint bolts
Hey folks,
I have a 66 rear end with an AN code (when I decoded, it is for a small block posi 4 speed with 3:55 if I recall correctly). What I was wondering about is this rear end has threaded u-joint saddles for the half shafts with caps & bolts that secure the u-joints, and I thought all small block halfshaft u-joints used u-bolts to fasten the u-joints to the differential yokes.
Can someone shed some light on this for me?
As always, thanks in advance!!
Hey folks,
I would suspect that the differential has been apart before, and the previous owner exchanged/replaced a few parts.
Larry
I suspect a previous owner of your car did some drag racing and added the big-block axles and connections as some extra protection for a a high-rpm "hole-shot" with slicks.
I have seen driveshafts come apart at the line or during the race and it causes all sorts of hell ......especially to the fiberglass.
