Adding on "Add-on" pulley
Old May 21, 2011 | 09:30 PM
cookie_monster's Avatar
cookie_monster
Default Adding on "Add-on" pulley
I'm gathering parts, information, and courage to add power steering to my 63 with NOM.
Simple question: Is installing the extra crank pulley as simple as removing the three bolts and stacking the new one in front of the present one?
Thanks in advance!
Old May 21, 2011 | 09:39 PM
Hitch's Avatar
Hitch
Not exactly you will need to get the correct two or three groove pulley and then remove the bolts and change out the pulley you have. I don't think that you can just add on a one groove pulley...
Dave
Old May 22, 2011 | 04:41 AM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
Thanks in advance!
sure, if your current one is the two groove pulley for a 300 or under hp engine. not sure about a hi po
Old May 22, 2011 | 12:51 PM
Kensmith's Avatar
Kensmith
I added on an aluminum 1 piece 3 groove pulley. I don't recommend adding a single groove pulley to an existing 2 groove pulley.
http://www.cfrperformance.com/HZ_8858_p/hz-8858.htm
Old May 22, 2011 | 01:16 PM
JohnZ's Avatar
JohnZ
Thanks in advance!
Yes, it is. That's how the system was designed, and how it was done at the factory. All of the usual suppliers have the "add-on" pulley to drive the power steering pump.
To Adding on "Add-on" pulley
