So I went to start my '66 on the week-end and it was dead. Charged the battery (took very little charge) and still nothing. I checked the ignition switch and have power to the start circuit when the key is engaged, I have power on both sides of the ballast resistor. Last night as I was checking the ignition switch I did get the car to turn-over and start, shut the key off and then on again and nothing. Still have power on start circuit when key engaged. Does this sound like a bad solenoid on the starter? The starter was replaced last year and probably has 500miles on it.
So I went to start my '66 on the week-end and it was dead. Charged the battery (took very little charge) and still nothing. I checked the ignition switch and have power to the start circuit when the key is engaged, Any suggestions/advice would be appreciated.
Allan
Two questions.
How did you determine the battery was dead and how do you know it took very little charge?
When you turn the key to "start", do you hear any noise?
Based on a little bit of information, it sounds like loose and/or dirty cable connections or a shorted battery.
Sorry, I could have been a little clearer.
I assumed the battery was dead. Put a charger on it and showed fully charged within 10 minutes. It's a smart charger that shows battery % charged, volts, amperage depending on what you select. Voltage across the posts are above 13 volts (Checked with a multi-meter). Posts are clean and a new power cable to starter was installed last fall. All accessories work, headlights, radio, etc. Just no starter engagement when I turn the key. When it did start last night the solenoid clicked......engaged the starter again and the car started. Shut it down, turned the key again and nothing. I thought maybe my ignition switch had given in hence me checking power with a test light onto the start terminal. I have power there when the key is engaged. It's just weird the car started last night and then was "dead" again. Dead is probably not a good description...... unwilling to engage the starter would be a better description
C1 of Year Finalist (appearance mods) 2019
I'm waiting for answers too, my car is doing the same thing. I replaced the solenoid and it worked fine for a while, now nothing, no click, nothing? Battery full, everything else works....
Usually, when starter solenoids start to fail, they will "click" without turning the starter motor. Sometimes it'll start the car and sometimes just "click". Eventually, all they will do is "click"! When that happens, the end of the big copper stud is worn to the point it won't make contact with the like armature contact and the starter won't turn even though the solenoid is still pulling in.
Another failure would be when the solenoid is not pulling in at all and it wouldn't make any noise.
If you turn the headlights on high beam, turn the blower motor on and blow the horn and the horn is good and loud and the headlights don't dim too much, I'd guess you have a bad solenoid and the rest of the wiring and connections and battery is good.
I'll get under the car this week-end and check for power at the solenoid while the key is (or should be) engaging the starter. If I have power at the solenoid, I'll assume a bad solenoid. Hard to believe that when the starter/solenoid is just about brand new. Aaarghhh!
I would be suspicious that the ignition switch may be the culprit based on it working then not working. You can bypass the ignition switch by jumping between two terminals on the solenoid directly but I don't have that information here at the office. Someone else could chime in on that. My $.02
If you want to do a test like Dave Tracy suggested, separate the connector on the 12 gauge purple wire located near the ballast resistor and connect the passsenger side with a jumper wire to the battery + terminal. If you have PG instead of a 4-spd, you may have a faulty park/neutral start switch. This same test will help you isolate that, too.
Crawled under the car this evening (with jack stands) and had my son turn the key. I had power at the solenoid when the key was in the start position. Tapped on the solenoid and the starter engaged...... bad solenoid. I'll take the solenoid off the starter I replaced a year and a half ago due to the broken starter nose and throw this solenoid away. Thanks to all.
