Solid Lifters Adjustment
Old May 29, 2011 | 07:28 AM
Pierre's Avatar
Pierre
Default Solid Lifters Adjustment
How often does anyone have to adjust or check the solid lifters adjustments on their engines? I build the 265 in my ’56 and the 283 in my ’57 many years ago and never looked at valve adjustments since, I’ve had no reasons to check them, no problems of any kind.
Does anyone check theirs at some regular intervals?
Pierre
Old May 29, 2011 | 08:11 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
With the engine idling, as long as the sound of the valve train seems to be uniform, with no single rocker arm making more noise than any other, I see no reason to make any adjustments.
Jim
Old May 29, 2011 | 08:15 AM
MikeM's Avatar
MikeM
Pierre
You've answered your own question. The best check is your ears.
Frequency would depend mainly on how many miles you drive, the condition of the locking rocker nuts and whether your thrash the engine will a lot of high rpm.
The state cops around here used to use '57 270 Chevys. From the sound of the engines in those things, it sounded like they never adjusted them. Sounded like thrashing machines.
Old May 29, 2011 | 03:09 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I try to adjust mine about every year or so ... which MIGHT be 3,000 miles or maybe less. I have it down to about 35 minutes (cold adjustment) including beer drinking so its no big deal. The last few adjustments I did had maybe 2-3 of the 16 valve settings requiring a 1/8 of a turn on the rocker nuts so not much is changing...I may go longer before the next adjustment....
Old May 29, 2011 | 03:25 PM
1snake's Avatar
1snake
I use sure-lock rocker arm nuts. In approx. 5000 miles, the adjustment is still perfect. When using them, the only thing that will change the adjustment is the stud pulling out of the head or the cam going flat.
Jim
Old May 29, 2011 | 06:13 PM
knockbill's Avatar
knockbill
Jim
jim,
do teh lock nuts you use fit under stock valve covers?
thanks,
john
Old May 29, 2011 | 07:44 PM
1snake's Avatar
1snake
Originally Posted by knockbill
jim,
thanks,
john
No problem when used with the aluminum covers.
Jim
Old May 29, 2011 | 08:04 PM
knockbill's Avatar
knockbill
Jim
thanks for the reply...
Old May 30, 2011 | 11:17 AM
OldKarz's Avatar
OldKarz
From: On the bank of the Columbia River..... Washington State
Jim
Old May 30, 2011 | 11:22 AM
JohnZ's Avatar
JohnZ
Back in the day, solid-lifter valve adjustment was part of the 12,000-mile tune-up schedule; that's a long interval the way we use these cars today.
Old May 30, 2011 | 11:52 AM
Powershift's Avatar
Powershift
Wow........that brings back some memories. Points, plugs, valve lash, oil change, and a new air filter.
Most of us Northern folks used to do their annual "tune up" after the spring thaw and the air started to warm up. We needed to be ready for summer vacation (families) or summer cruising (teenagers). And throw in a good wash and wax (Blue Coral) to remove the winter grim.
Larry
To Solid Lifters Adjustment
