block casting numbers - 2 different ??
Old Jun 9, 2011 | 11:02 AM
pusher_sr's Avatar
pusher_sr
Default block casting numbers - 2 different ??
after taking off my valve covers, i noticed that there are two different numbers on the heads. is there a separate number (7 digits) for the left side and a "different" one for the right side ? i was wondering if they don't match, do i have a non original head ?
Old Jun 9, 2011 | 11:10 AM
5thvet's Avatar
5thvet
The numbers were not different for left and right side. What are the numbers on yours and someone can help with the ID.
Old Jun 9, 2011 | 01:28 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
the head #s were/are different on my 1970 LT1 crate engine; but don't ask me what they are are, i don't want to take the valve covers off again to see.
Bill
Old Jun 9, 2011 | 01:49 PM
Mike Ward's Avatar
Mike Ward
Some years had two or more different head casting numbers running concurrently. Nothing to do with left or right though.
Old Jun 9, 2011 | 03:13 PM
Blue 396's Avatar
Blue 396
with Mike
not all that common but not unheard of
Old Jun 9, 2011 | 04:08 PM
BrettG's Avatar
BrettG
Check the casting dates for each head, that will be a key piece of information.
Old Jun 9, 2011 | 05:15 PM
scorpion1110's Avatar
scorpion1110
Bill
I'd guess "186" heads or "040" or "041". The 186's are DZ 302 and high horse 350s and I think the 041s were the occasional alternative. I think 040s are high horse truck.
Old Jun 11, 2011 | 11:16 PM
pusher_sr's Avatar
pusher_sr
Default does this head number match ??
here's the number from one of the head's on my 1966-327-300 hp motor. 3890462 with D66. from the research i've done on block casting numbers, i can't seem to find a match. can anyone match this number up with a motor ?
the other head is numbered 3858174 which does match.
thanks. ted
Old Jun 11, 2011 | 11:28 PM
vettebuyer6369's Avatar
vettebuyer6369
Either way, "head" numbers are different from "block casting numbers."
Old Jun 12, 2011 | 01:09 PM
5thvet's Avatar
5thvet
The 3890462 head was used on 66-68 Camaro/Nova/Chevelle 275HP,
67 Corvette 327, and 67 Z28 with a 302. I couldn't find the 3858174 in any reference I have, Are you sure of that number?
Old Jun 12, 2011 | 01:18 PM
Mike Ward's Avatar
Mike Ward
thanks. ted
Maybe 3852174 ?
'63-'64 327 cu/in, 1.72"/1.5" valves.
Old Jun 12, 2011 | 02:42 PM
65GGvert's Avatar
65GGvert
3858174 is the BLOCK casting number for 65 66 327. Don't know about the heads.
Old Jun 12, 2011 | 02:53 PM
JohnZ's Avatar
JohnZ
thanks. ted
Almost all 66's used 3782461 heads, although a few very late 66's used 3890462 heads. 3858174 is the '66 block casting number.
Old Jun 21, 2011 | 11:53 PM
pusher_sr's Avatar
pusher_sr
Default head #'s match with the month ??
on my small block 327-300 hp., i have the # 3890462 with D66. i'm figuring my car was built in may john, but you are saying the numbers i have came out later in the year. i'm a little bit confused. any more info ? thanks. ted
To block casting numbers - 2 different ??
