Ignition removal
Old Jun 9, 2011 | 08:14 PM
ErminewhiteC2's Avatar
ErminewhiteC2
Default Ignition removal
Does the key have to be in the accessory position to insert the paper clip in my '64? I have never been able to turn it to that position. I have had this car for 30yrs, and have always been able to take the key out of the ignition in any position. The key works in the glove box door, so I am thinking it is the correct one. I recently bought a new ignition tumbler and door lock set with keys.
Thanks, Rick
Old Jun 9, 2011 | 08:17 PM
5thvet's Avatar
5thvet
Yeah, turn the key to ACC position push the paper clip in as you turn the key a little further left and pull it out.
Old Jun 9, 2011 | 08:27 PM
ErminewhiteC2
It won't go to ACC
Old Jun 9, 2011 | 08:35 PM
oldsarge's Avatar
oldsarge
Hope you are putting it in acc before you are putting in the paper clip.Try it in the lock or on position.
Old Jun 9, 2011 | 09:50 PM
5thvet's Avatar
5thvet
So you have a new one and are trying to get the old one out? Try and jiggle the key while applying pressure to the ACC position. Also try pulling the key out a hair while turning it to the ACC position. Sometimes mine won't go to ACC without a little convincing!
Old Jun 9, 2011 | 10:23 PM
ErminewhiteC2
5th vet
You are right. What do I do if I don't have the right key for the ignition?
Old Jun 9, 2011 | 10:30 PM
5thvet's Avatar
5thvet
Does the key work to start the car?
Old Jun 9, 2011 | 10:31 PM
ErminewhiteC2
Yes, but I can put any key in it and the ignition turns.
Old Jun 9, 2011 | 10:37 PM
5thvet's Avatar
5thvet
What do you mean any key? If you have a 64, they only had one key which worked the ignition, doors, glove box, and spare tire lock. Do you have more than one key?
Old Jun 9, 2011 | 10:40 PM
ErminewhiteC2
A key from any car, or no key at all. I just have to turn the bezel
Old Jun 9, 2011 | 10:44 PM
62Jeff's Avatar
62Jeff
Sounds like you don't have the correct key.
My guess is that with the correct key, it would go into the ACC position. Without putting it into the ACC position before removing the correct key at some point in the past, the ignition switch was left in a position that even a screwdriver will start it.
Old Jun 9, 2011 | 10:47 PM
5thvet's Avatar
5thvet
Oh my........ Does it spin in both directions? If so can you spin it to the left and see if it stops. If it does try pull it out with a key inserted for a little leverage.....or if that fails you could take the lock out of the glove box and have a locksmith make a key for it and try that key in the ignition to see if you can get it to ACC.
Old Jun 9, 2011 | 10:49 PM
62Jeff's Avatar
62Jeff
As per his opening post, the key works in the glove box lock but doesn't help the ignition got to ACC.
Old Jun 9, 2011 | 11:00 PM
5thvet's Avatar
5thvet
Do you have more than one key? Even though they all should be the same on a 64 I would try them all ( if you have more than one) and like Jeff said with the right key it may go to ACC.
Old Jun 9, 2011 | 11:28 PM
5thvet's Avatar
5thvet
Rick,
It could also be that one of the pins in the tumbler is stuck in the up position for some reason ( maybe the wrong key inserted at some point in time). Try spraying some WD-40 into the lock and then try jiggling it. It may take some time but if it is a stuck pin it should free with enough WD-40 and jiggling. Oh well good luck. Last resort would be get a locksmith to come out. More bucks but they can do it.
Old Jun 10, 2011 | 11:31 AM
ErminewhiteC2
I guess I will try the WD40 first, but I have my doubts. Like I said earlier, I have had this car for 30 yrs and the key has never worked correctly.
Thanks, Rick
Old Jun 10, 2011 | 12:06 PM
5thvet's Avatar
5thvet
I'd try it because I have seen it work before. You may have to do it a few times but it's worth a try befrore having a locksmith come out.
Old Jun 10, 2011 | 01:15 PM
pittsaj's Avatar
pittsaj
Sounds like you have the wrong key or a copy that was incorrectly cut..
Check the glove box lock to be sure all the pins are being correctly lined up with the key inserted.. If not, it may be the key is close enough for the glove box lock but not the the Ign Switch
A locksmith will be able to easily cut a new key if that is the case
Old Jun 10, 2011 | 08:24 PM
jdk971's Avatar
jdk971
i have the same problem with a 63 impala. the key goes no farther than off. no lock or
acc. jim
To Ignition removal
