Temperature Sensor Issue
Old Jun 11, 2011 | 07:51 AM
rob1964vette's Avatar
rob1964vette
8th Gear
Default Temperature Sensor Issue
I have an aftermarket intake manifold (Weiand Street Warrior) that I am running that has a 3/8 in NPT opening for where the temperature sensor goes. The temperature sensor for my year vette from Dewitts is a 1/2 in NPT. Does anyone know the resistance range of the factory temp sensor? I can probably source a 3/8" NPT temperature sensor that will work with my factory gauge with that information. Any help is appreciated. Thanks Rob.
Old Jun 11, 2011 | 08:06 AM
knockbill's Avatar
knockbill
can you connect an ohm meter to it and heat it in a pot of water to measure its range? i've done it to check accuracy,,, put a thermometer in teh water to check calibration...
Old Jun 11, 2011 | 08:10 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Unfortunately, the resistance varies depending on manufacturer ... see attachment.
Doesn't mean you can't come up with something close though.
File Type: pdf
Old Jun 12, 2011 | 03:42 PM
rob1964vette
8th Gear
Default Temperature Sensor Question
Thanks for the insights and the link with the chart, it gives me a starting point to the solution. Appreciate your time, this forum rocks!
To Temperature Sensor Issue
